Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Question for you Vette Guys!!!
Old Dec 17, 2006 | 07:31 PM
  #41
I8COBRA's Avatar
The Z06 is 38 lbs. lighter than the FRC.
Old Dec 17, 2006 | 08:12 PM
  #42
StealthZ06's Avatar
Originally Posted by Cobra4B
^ Yes I know... there's lots of little things.
If a stronger drive shaft, a significantly better block, and better pistons are little things then call me crazy.
Old Dec 18, 2006 | 01:26 AM
  #43
Cobra4B's Avatar
In 2001 all Corvettes got the LS6 block.... so did many F-bodys. They also all got the LS6 intake manifold.
It has windows at the bottom of the sleeve for better pressure distribution. The driveshaft is lighter, not stronger. In 2001 all C5's got better driveshaft couplers w/ a revised design... the don't have the degradation issues of pre '01 cars when beat on. Also '01 and up cars have much better rod bolts. If you're going to put H/C on a pre '01 LSX and spin it over 6000 rpms regularly a rod bolt upgrade is suggested.
Old Dec 18, 2006 | 02:15 AM
  #44
jdhommert's Avatar
If your going to mod the hell out of it, especially for Road Racing, i'd get a FRC, and slap a T1 package on it, with a decent alignment and tires. Will outhandle a zo6 easily. They say a FRC is 12% stiffer than a coupe. All of them come with Z51's and six speeds too. Almost as light a z06 too.
For me its a Z06 that i want though.
Old Dec 18, 2006 | 05:12 AM
  #45
I8COBRA's Avatar
Wrong, not all FRC's came with Z51, most but not all.
Old Dec 18, 2006 | 07:02 AM
  #46
SilveradoSS500's Avatar
Well it just comes down to what I find, when I want to buy it. Mid January or this week i will have a vette. Either way its going to be faster than a stock Z06 and I plan on modding the hell out of it and beating the hell out it.....Can't wait!!!
Old Dec 18, 2006 | 08:07 AM
  #47
Cobra4B's Avatar
Actually he's right... all FRC's came w/ Z-51 and a 6-speed from bowling green.
Seriously though... the above advice is right. If you want a track rat you don't need more than 350 ponies. Get a cheapo FRC, do a fluid enema, T-1 suspension kit, seats, harnesses, and tires/allignment and you'll be flying.
Seats and hoosiers or (insert slick of choice) will make you faster than any H/C package.
However... if you're a noob to HPDE's then get an FRC + tune up/fluid enema then some harnesses and harness bar etc... then go learn first. Commit to running 4-5 hpde's before any mods.
You'll find that most driving instructors leave their cars stock... esp w/ a z06... many have a stock car w/ wheels/slicks and harnesses.
Old Dec 18, 2006 | 08:08 AM
  #48
Cobra4B's Avatar
My Z06 is becomming more of a street machine... I'd like to get a POS (relative term) '99 FRC, gut it, and make it a track only car.
 Michael S. Palmer
Old Dec 18, 2006 | 10:37 AM
  #49
David Gordon's Avatar
Buy my car from me and put the T1 swaybars and racing pads on the brakes and you will be ready to go. All the torque from the big motor and it has lots of upgrades including 3.90 gears and the aluminum floor pan under neath that ties the car together as well as hardened output shafts and the rearend cage. It only has 17k miles and very few on the tranny and rear and maybe 5 on the motor. $30k and with maybe $2500 more you are race ready.
432-557-1610
Old Dec 19, 2006 | 10:42 AM
  #50
hummmm
Old Dec 19, 2006 | 12:56 PM
  #51
NDFORSPD's Avatar
haha fluid enema!
Old Dec 19, 2006 | 01:17 PM
  #52
Drewstein's Avatar
The driveshafts on these things are solid, it's the output shafts we have to worry about.
Better block? The LS6 block can't hold anything the LS1 couldn't and if anything the LS1 is better to throw boost at due to C/R. I threw a pile at my pistions as well and they're not known to go in these cars either so no worries there.
The $$ spent on a Z goes into the name more than the mods you get. If you're going to mod a car, the FRC or coupe are better choices. If you want to drive a 350hp car that will hold decent value, get the Z.
Old Dec 19, 2006 | 04:58 PM
  #53
The blocks are basically the same. There is no strength difference. Mine has all the modes you will ever use, electric water pump for sustained high speed driving and all hardened shafts and a very heavy duty clutch. Even has Baer rotors in front just need to add racing pads and the T1 kit for throwing her into tight corners.
Old Dec 19, 2006 | 06:02 PM
  #54
Cobra4B's Avatar
David hate to burst your bubble the an EWP is a drag racer mod... not a road course mod. At high RPMs they flow less coolant that the stock pump thus, "electric water pump for sustained high speed driving" is not an accurate befefit statement.
Old Dec 19, 2006 | 08:10 PM
  #55
The car runs very cool with it and the needle very seldom ever moves.
Old Dec 19, 2006 | 08:21 PM
  #56
StealthZ06's Avatar
Uhhh no they're not...
The aluminum block casting on the LS6 deletes machined holes in the LS1 bulkhead and adds cast-in "windows" that allow better bay-to-bay breathing. On the downstroke, the pistons push air back toward the crankcase, creating backpressure or resistance, and that translates into parasitic horsepower loss because it resists piston motion. With the overtravel windows, air is allowed to move more freely between crankcase bays, thus relieving the unwanted pressure.
Old Dec 19, 2006 | 08:54 PM
  #57
It was my understanding that all LS1 or 6 blocks were all the same after 2002. Mine is an 04 block.
Old Dec 20, 2006 | 10:42 AM
  #58
Cobra4B's Avatar
Actually in '01 all Corvettes got the LS6 block and intake manifold. The difference is in the heads, cam, valve-train, itake air box, and exhaust setup.
Old Dec 21, 2006 | 11:42 PM
  #59
Which the V has, I might get another one but it sounds like I should check out hommies car in Midland, (im from dallas) i plan on buying either vette or v in dallas so.......I think I would go with a FRC and dumb 6k into that week.....
