Question about nitrous install on C-5
The kit says it works with any EFI Engine, but seems more marketed towards Mustangs.
Compucar
Bottle in a Bag Kit
Nitrous in-a-bag (Pro Street Heat)
The Pro Street Heat was designed to be the simplest nitrous system on the market to use and install. This is a "dry system" injecting only nitrous into the motor. It works by "tricking" the computer back into the cold start mode. In cold start mode, the computer injects more fuel into the motor just like a carburetor does when the choke is on. Other sensors detect the oxygen rich air and adjust the fuel mixture and timing to compensate for this extra income of oxygen making this system near fool proof on performance. This kit comes with jetting from small, medium, large, extra large, and kickin ***. This will give you approximately 20 to 100 HP on your motor. Installation on this kit takes 10 minutes to complete and the kit can easily be place onto other vehicles in the same amount of time. This kit is designed to work on any EFI (fuel injected) vehicle.
Key Benefits:
This is a great beginner kit.
The design of this kit means no adjustments to the motor.
No one will know you have the kit on the car
Part Number: 690310
Any of the forum vendors can hook you up with dry a dry nozzle, they are about $20 plus the bung is needed too.
Assuming the nozzle is a -3AN? you will also need jets for the new Nozzle.
Robert
The way you describe does work sort of. It will have a lean spike and the reading will be more diluted and thus a leaner a/f, unless going big shot.
Robert
You need to index your nozzles so you know they spraying the pattern where you want it. Everytime I have seen a lean condition it's been nozzle location/postion and/or sytle errror. Maybe we can get ya fixed up?
I am upto 250rwhp dry shot and haven't blown passed the MAF on the entire journey, actually you'll find the oppisite in correctly placed nozzle(s), if your to rich (which is more common than lean) you can slightly rotate the nozzle to allow some of the spray to bypass the MAF wire and thus leaning it out. However, if the nozzle is too far away and a lean condition is present, which is the normal outcome, then going into the pcm is the only recourse.
Robert
I would get others opinions and go to the dyno. Try different things on your car to see what works for you. What works on some cars doesnt work on some.
Robert
