Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Heads up Display?
Old Jan 11, 2007 | 03:09 AM
seabirdak's Avatar
Default Heads up Display?
I was curious what all does the Heads up Display show? Does it show your RPM's too? (HUD on the C5)
Old Jan 11, 2007 | 04:43 AM
PA Z06's Avatar
It shows Speed, will flash shift when at redline, then you can toggle oil pressure, oil temp or engine temp.
On the c6 is has a tach. Hope that helps
Old Jan 11, 2007 | 07:15 AM
seabirdak's Avatar
Right on thanks for taking the time to answer!
Old Jan 11, 2007 | 08:15 AM
MJD's Avatar
MJD
Yes, it will display RPM. It will allow you to costomize the display although somewhat limited. Will also give warning if low on gas or check engine light comes on.
Old Jan 11, 2007 | 02:49 PM
seabirdak's Avatar
Does that depend on the year HUD? Is it for all 01 and up I think its standard?
Old Jan 15, 2007 | 10:13 AM
95stsrider's Avatar
Does anyone know if it’s possible to add the HUD to a 04 vette. My father wants it on his car something serious and I have no idea if it’s even possible. Please let me know.
Old Jan 15, 2007 | 10:57 AM
35thUCF's Avatar
I am sure it can be done, you will probably need the wire diagram of the C5 interior, the new dash, the HUD projector, and maybe the windshield (which contains the combination lens)
Old Jan 15, 2007 | 11:23 AM
mach2004's Avatar
Go to the corvetteforums.com. There are threads with venders names and #'s . It seems to be an easy add-on.
Old Jan 20, 2007 | 07:08 PM
SteveDoten@ARH's Avatar
Closed ex-Sponsor Account
yes, it can be upgraded, I've done a few
Old Jan 20, 2007 | 08:31 PM
SilveradoSS500's Avatar
Could you add it????
