How much was your clutch install???
I think its that time for a new clutch and I just wanted to get some Ideas on priceing to see if I get a good Deal. I would do it myself But I heard if you flex more than 5 MM between the Rearend and trans you destroy the trans internals, and I dont want to deal with all that junk.
on the torque tube you will see this illustration
just dont let the tranny/differential drop to low becuase you will risk the back of the motor hitting the firewall.
Its a little tedious, but it was a little easier (IMO) than doing a clutch on an Fbody*. The daunting part of the ordeal is removing the rear cradle. It isn't that much work, but it is a big/heavy part that intimidates people. That said, make sure you have an idea of WTH you are doing before you bust out the air tools
.A tranny jack like the one from Harbor Freight is critical. Actually, a couple of tranny jacks would be ideal. *I am used to removing a T56 from an Fbody with a jack and then picking it up myself. With a good tranny jack, I'm betting the Fbody task wouldn't be nearly as bad.
Ryan
