Anyone running an LS6 clutch with mods?
My choices are:
Take my chances with another stock clutch.
Pick up a "middle ground" clutch. Cartek, RAM, etc.
Textralia.
Obviously, if money wasn't an object I'd already have a Textralia. A stock clutch is almost 1/3 of the price and my stock clutch has been great up until this point. I'm trying to figure out if the clutch had too much mileage on it, or its demise was attributed to the header installation.
So, is anyone drag racing their bolton Z06 and not having issues?
Ryan
All suggestions are welcome
.Keep in mind I like to beat on it a bunch. I'd say that 30 of those passes were 1.8 or better 60's with street tires. Yes, there is a little slipping going on ;-).
Gotta pay to play. Not a single goddamn clutch for the vette has a perfect track record under abuse. Everything gets busted. Stock, RPS, Tex, McCloud, Excedy, Spec, Ram, LS7.
The stock clutch will hold a good deal of power, mine held 600rwhp for a while, but none of that was heavy useage (I only race ricer style).
If I had know that I would have tried one before I invested a TON of money on the Mcleod setup, now with Kevlar, killer clutch way too much money/time invested.
. Like I said, the clutch was fine for about 50 passes and stock power levels. It is a fact that the 02+ LS6 is an improvement over the 2001 LS6 piece. So, there is reason to believe that an 02+ stock LS6 clutch would give me as good or better performance as I initially experienced.
I'd rather wear out clutches than break rearends. The labor is free since I do it myself
. However, the issue is "chancing" another clutch and potentially wasting 4-500 bucks. The Textralia is a for sure deal, but $$$. I will sit tight and start saving
.Ryan
I've had a Spec, Ram and now a Textralia. The Ram **** the brick, the SPEC vibrated... The Tex has been the best so far, it drives like stock but hooks.
One of my friends blew his "LS6" clutch on a 385 rwhp car with low mileage.... Didn't slip, just broke....
If you are interested, the Fidanza web site has an interview on the home page and they guy from Fidanza explains all the different clutch materials and what they are good for and how they perform. Interesting if you don't know much about clutches. Also noteworthy, Fidanza now makes a clutch for the C5 in four flavors.
P.S. I have a '99 FRC.
I'm at 450rwhp and the Tex should hold up just fine. I added a hardened output shaft at the time of the clutch install since this is known to be a weak link on a Vette. I chose the Tex due to overall positive feedback and good customer service from the company.
Good luck with your decision.
