Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Shifters..
Old Feb 12, 2007 | 07:31 AM
BitViper's Avatar
Default Shifters..
Are the shifters from an LS1 and 04 Z06 interchangeable..
Im thinking my first mod..after the antenna of course will be a shifter..Id like to get a "Lou's" short shift and a matching short throw unit like B&M or Hurst etc...
Old Feb 12, 2007 | 08:01 AM
dixonk's Avatar
do you mean to ask if the vette shifter will fit on a fbody or vise versa?
Old Feb 12, 2007 | 08:49 AM
BitViper's Avatar
Yeah....It was early when I typed teh above..Im thinking of ways to avoid the vette tax..if teh trannys are the same then it follows thet the shifters migt be the same etc....
Old Feb 12, 2007 | 08:57 AM
dixonk's Avatar
I know the vette shifter is totally different than the fbody. For the vette it's smaller and the stick comes with the shifter assembly whereas the pro 5.0 or whichever shifter you prefer generally lets you choose the stick you prefer to use e.g. Lou's short stick. The Fbody shifter has a big plate and the bolt pattern is different.
Old Feb 12, 2007 | 09:10 AM
dixonk's Avatar
Here are pictures of both the fbody t56 shifter and vette t56 shifter both are ripper shifters.
Corvette:
Fbody:
Hope this helps
Old Feb 12, 2007 | 02:28 PM
Azrael's Avatar
Totally different shifters, otherwise I would be sporting a Pro 5.0 in the Z06 and not the B&M Precision Ripper shifter.
Old Feb 13, 2007 | 01:07 AM
dixonk's Avatar
You must be having the same problems as me then with the Ripper shifter. Hard as hell to shift into OD and R huh??
Old Feb 13, 2007 | 08:59 AM
BitViper's Avatar
Yeah I realized teh sticks were diffrent but I was thinking that how the attach to the tranny might be the same
Im thinking Im going to have teh same issues wtheh stock vette shifter that I had with the vette shifter..that thing is really long..which shifter is shortest
Old Feb 13, 2007 | 09:22 AM
Azrael's Avatar
Actually I am having a hydraulic issue where the clutch will not disengage fully and it is hard to down shift or shift into first without pumping the clutch. Otherwise the newer style Ripper has been great, I love it over the stock shifter!
Old Feb 13, 2007 | 09:28 AM
dixonk's Avatar
I loved the feel of the stock shifter but that thing was damn sure tall wish they came with short shifters stock. Or better yet maybe if we were able to just by short sticks to go on the shifter would've been nice too. I have to do a lot of parallel parking here and that 1 to R and back again is really getting to me.
Old Feb 13, 2007 | 09:29 AM
dixonk's Avatar
The B&M Ripper shifter is nice and short I haven't seen one shorter yet.
Old Feb 13, 2007 | 11:40 AM
scramblerman's Avatar
I just finished installing the BPP shifter in my Z06. I did alot of research before buying one. I really liked it because you can adjust the stifness of the shifter. I ended up going with the lightest springs. Also too you can adjust the handle of the shifter to where you feel most comfortable with it. Haven't had the chance to take it out yet, a bit of a blizzard going on here right now. Although that 2-3 shift is going to be really fast!
Old Feb 13, 2007 | 02:41 PM
BitViper's Avatar
I heard of one guy who cut his ~1" then spun on new threads
Old Feb 13, 2007 | 03:14 PM
here is a link if you want to just keep your stock shifter and just cut the handle down. Although you may have to sign on to that website if you have not already.
http://www.z06vette.com/forums/showthread.php?t=40527
Old Feb 13, 2007 | 09:02 PM
vetred's Avatar
If you can read directions and FOLLOW them Dude,.............Its the "HURST"
Old Feb 14, 2007 | 12:49 PM
SilveradoSS500's Avatar
I have been doing alot of research myself! I have driven a Z with the Hurst and it was a nice hard racing syle shift!!! Thats what Im looking for....
Old Feb 15, 2007 | 09:44 PM
vetred's Avatar
Originally Posted by SilveradoSS500
I have been doing a lot of research myself! I have driven a Z with the Hurst and it was a nice hard racing style shift!!! That's what I'm looking for....
Well I would only add to that, that if it was then that was the way it was SET-UP! You can set them to do anything firm, soft whatever!
Old Feb 19, 2007 | 11:15 PM
BitViper's Avatar
Which stick is the shortest in lenght/height
Old Feb 20, 2007 | 06:27 AM
V-seriesTech's Avatar
IF you know how to bang gears, get a hurst. There isn't a better shifter.
Old Feb 28, 2007 | 11:06 PM
96inSA's Avatar
I am very happy with the B&M Ripper.
