Broke the rear end yesterday!!!
Went to the track for some fun yesterday and left on a trailer. Pulled up to the line, took the rpm's to 2500,dropped the clutch, and snap!! I believe that the limited slip let go in the rearend from the way the car acts. I will be able to get into the shop today and start to tear it apart and see forsure. What are the options on different brands of limited slips out there other than the factory setup?
You didnt have a brace or anything upgraded i the read? What kind of tires were you on? I usually launch mine at 3000+ on street tires and so far so good. They actually hook also. Fill us in as soon as you find out the deal!
Something like this happend to me it was when I downshifted I just herd a snap under my shifter.I thought my clutch broke then after that I thought My slave and master was gone.Then rear diff and and finally tranny after checking all my parts and guessing all it was is that my torque tube internals broke.I wasted like 3 thousand replacing fork keys clucth's and tranny parts when I could of only wasted 600 and got it running but atleast I know my drivetrain is in a great condition.
Seems like my local C5 friends slip the clutches out real fast they don't dump it.
Werd!
Unless ofcourse your tire/diff can handle it. Some guys launch HARD...5500rpm and higher clutch.
Most likely young split the output shaft...or even worse...a possibly cracked diff.
Any fluid loss? Look at the caseing(obvioulsy)...then look in front of the diff, where it meets the trans housing/caseing. Sometimes they break there.
Best wishes man...
thats nuts, i launch at 4k, clutch dumps w/ a mcleod street twin/kevlar disk setup on my 408 Ci stroker lol.
im making over 450 RWTQ @ 4k and running ET streets.. no breakage yet (knock on wood)
ha!
I thought it was crazy also. The car only made 310RWHP and broke the rear. There wasn't any fluid loss or any noticable cracks any where. I am planning on it being the shaft. So the plans are to replace whatever broke and install a set of 4.10's while it is apart.
