Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
ABS and traction cont. lights
Old May 6, 2007 | 09:27 PM
dust6928's Avatar
Default ABS and traction cont. lights
my girl has an 01 c5 that every once in awhile the abs and trac. control lights come on at startup. you shut it down and restart and they do not come back on. anyone else had this happen and if so what did you find to be the problem? also, the pass. side window works when it wants to and the pass side door lock switch always works, anyone had an issue with this?
Old May 6, 2007 | 11:35 PM
SVT BAIT's Avatar
i had my abs light on it actually stayed on if ur abs sensor is cut ot messed up ur looking at around 400 bucks i think or else if u find a wreck vette u can get it cheaper!
Old May 7, 2007 | 05:21 PM
BBM98C5's Avatar
Mine has done that once and both lights came on once after I hit a pothole. I just restarted the car and all lights went off. This is nothing to worry about.
Old May 7, 2007 | 06:21 PM
Wide Open's Avatar
Mine did that sporadically a couple of times then went away for several months before returning. This time it wouldn’t go away. The EBCM had shorted internally. Replacement cost $870. Hopefully that isn’t your issue.
Old May 7, 2007 | 10:16 PM
jargan04's Avatar
What codes are you throwing? Hope and pray it's C1214.
Old May 8, 2007 | 12:46 PM
dust6928's Avatar
havent read the codes yet, gotta get with a buddy who has a scanner. just odd to me that it has only done it a few times over the last 6 months.
Old May 8, 2007 | 05:36 PM
mikep2002's Avatar
Dont need a scanner you can pull them up on the dash. Just turn the ingnition on hold the (options) button and press the (fuel) button 4 times. It will run through all the systems and show any codes.
Old May 8, 2007 | 08:54 PM
Wide Open's Avatar
I didn't know that. Learn something new everyday.
Old May 8, 2007 | 11:17 PM
dust6928's Avatar
thanks alot mike, you just increased my workload. there were 10 codes total thrown. most were battery issues which have been taken care of, a few loss of communication with bcm which i hope was because of the battery situation, then the tire pressure monitor which i knew was a problem and one that threw me was c1214 which said it was a solenoid valve/relay open. not sure what that one is if anyone can elaborate please do. and mike, that is a great tool man that should go underneath the sticky for diagnostic codes man, great info, thanks!!
Old May 9, 2007 | 12:49 AM
AllaboutdaZ's Avatar
mine does the same once in while but it is said to be a faulty groundinhg point in the engine bay thats why sometimes it goes on and sometimes it goes off not that much of a big deal
Old May 9, 2007 | 07:58 PM
mikep2002's Avatar
I am the last person you want to talk to in refernece to electrical ****. I know nothing at all. Pulling up codes was a simple answer. From here on out your gonna need help from a technical expert. I would strongly recommend you heading over to corvette forum.com they have some guys that are great with the technical stuff. There are some stickys to trouble shoot electrical codes and grounding locations. I dont know if thats a good thing or a bad thing the old lady having a vette . Atleast you know she has some cash. Good Luck to You
Old May 9, 2007 | 08:37 PM
mikep2002's Avatar
Just to add on a bit here is a place I visit for finding out what my codes are. Please excuse me for not providing a direct link. http://www.stengel.net/diccodes.htm
That will give you a basic overview. They have almost all the codes listed there. I think if your car is post/2000 there are a couple codes not shown on this page.
