Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Pulling engine from top???
Old May 12, 2007 | 12:27 PM
SideStep's Avatar
Default Pulling engine from top???
I am pulling my engine (heads already off) out from the top. Any advice on getting it out of there???
Old May 13, 2007 | 11:36 AM
mikep2002's Avatar
It will come out nice and easy its going back in that is a pain in the ***. I pulled mine with the heads off. Put it back in with heads on. I tried everything to get that puppy back in. I had to lower the 4 craddles bolt to the end threads to get oil pan wing to clear. Just remember you also gonna need to disconnect the shocks and A-arms,brake lines to lower the cradle no biggie though. You should also dissconnect the power steering line in the center of the steering rack just protect the threads. Recommend doing a clutch at the same time.
Old May 14, 2007 | 03:17 PM
SideStep's Avatar
You mean, you put it back in with the heads already on the block??? I had planned on waiting until I had the new block back in before I installed the heads...
Old May 14, 2007 | 07:28 PM
2MuchRiceMakesMeSick's Avatar
maybe this will help
Old May 14, 2007 | 08:30 PM
mikep2002's Avatar
That is the link I used. This guy has great info. I installed mine as he did with the heads back on and had to lower the front cradle it`s not a big deal. I only needed about 3/4" to clear. I think your better off putting it in with the heads on. Reason being you can better adjust everything. Figure with the heads on you have good access to the all of your rockers and the abillity to turn crank without dealing with the steering rack to adjust and check preload. And if by some crazy chance you screw up a thread or something its much easier with the motor out. Just watch those wire harnesses there tight in the back. Just my Opinion from my experience with the project... Good Luck
Old May 15, 2007 | 07:44 AM
SideStep's Avatar
DAMN! Thanks!
I am pulling it in 4 weeks, this will help tons!
Old Aug 27, 2007 | 06:45 PM
DALLAS's Avatar
i did mine using that link also. one thing that helped me out a lot on the install was making sure the motor was level before stuffing it, (i had to attempt it twice)
Old Aug 27, 2007 | 09:55 PM
Z06PSI's Avatar
I think I am going to use a lift and just drop the entire drivetrain with wheels on. I have a rear to change along with a motor. Anybody have any hints or links?
Old Aug 28, 2007 | 07:48 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I used that write up also for pulling and installing my engine.
Keith
Old Aug 28, 2007 | 07:54 AM
I was very supprized how easy it actually was.
