Stock 03z06 fuel pump limits?
What are the limits of the fuel pump on an 03 z06? What are my options for better pumps?
Dave
470 on motor is nothing to shrug about. How does the car feel on just the motor?
If you plan on adding alot of power keep reading...
Ive done alot of research on this because I have an 03 with the single return system. (there is no return fuel line back to the tank. everything is inside the tank fp fpr filter..etc) Ive came to the conclusion that its best to leave everything inside the fuel factory fuel tank alone, run a bigger feed line, add a return line, and integrate the factory line with second pump.
The reason im doing this is because the electronics involved with the pump on a single return system is too complicated to figure out(at least more then I want to spend time on) Corvettes have two different tanks (one on the passengers side and the main one on the drivers side). If you are at 50% fuel then the drivers side tank is full and the passengers is empty but this is not the case if you are at 75% fuel. Since there is two tanks of course there is two fuel pumps. One pumps the fuel to the front of the car and to the second tank and the second one just pumps it to the first tank (drivers side)
you can read more about it here
http://www.corvetteactioncenter.com/....php?qstId=589
The car feels great on motor. I think im getting the knock sensor issue worked out so i can go from 21* of timing to 28 and probaly see a few more ponies and alot more mid range torque.
I want to do the kit to run some supras this weeken. I think it should be fun with all that gobs of torque. I just put the textralia exo-skel clutch in the car so I should be fine on the transmission (me thinks!).
You forget im going to put the cobra back in the shop for a twin turbo set up. Just waiting on curtis's car to be finished with the clutch set up. Im already looking for a piston/rod set up for the vette as well as I am going to build a bottom end for the car since I know its going to blow up on the jug. I am not converting from the ford to gm side. I am just pretending im sweeden and staying nuetral.
Anyways glad to hear you are getting your timing issues worked out with new Sensors. I hope you like the difference with the extra timing. Your motor should wake up a bit. Keep us updated, your car must feel like a monster. Be safe !!
