Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
clutch making wierd noises
Old Oct 15, 2007 | 05:20 PM
pdd's Avatar
pdd
Default clutch making wierd noises
sounds like somethings loose when engage then disengage the clutch. it doesnt do it all the time. sometimes when im riding the clutch say on an incline at a complete stop, it makes wierd sounds, like spinning a 45ib steel gym weight on a steel peg. any ideas whats happening?
Old Oct 16, 2007 | 12:30 AM
DarkC5's Avatar
your symptoms aren't really well explained, but sounds like either a bearing or a pressure plate in screwed. quit driving it and tear it apart to inspect.
Old Oct 16, 2007 | 12:48 AM
pdd's Avatar
pdd
whats in screwed? also its a spec 3 clutch
Old Oct 16, 2007 | 09:04 AM
02ZOh6's Avatar
Throw-out bearing? It really should make that noise all the time though.
Old Oct 16, 2007 | 06:18 PM
pdd's Avatar
pdd
its a new throw out bearing, master and slave when i installed the spec 3 clutch a few years ago. car has about 11k miles on it and only been to the track once for 3 runs. i never beat on the car either
Old Oct 16, 2007 | 06:19 PM
thecorrectformula's Avatar
I have the same exact problem. It's the throwout bearing on mine.
Old Oct 16, 2007 | 06:23 PM
pdd's Avatar
pdd
no ****, did it do it all the time or just random?
Old Oct 16, 2007 | 06:53 PM
It started as a random occurance. At first I thought it was the ORY banging on the floor but then it got worse. Now it does it all the time pretty much. Under heavy throttle in first I can't hear it most of the time (Maybe my engine/exhaust is just too loud.) Mine sounds like someone is beating a steel bar up against the engine block. It sucks because it's so bad its retarded my timing.
Old Oct 16, 2007 | 07:57 PM
02ZOh6's Avatar
Doesn't matter. I changed mine - the master cylinder and it was making noise before the break-in period was over. Not a big deal though. Every manual perfromance car I've owned has done it.
