difference between the c5 z06 and a norm c5?
differences are minimal compared to the c6 z51 and the c6 z06.
Totally different animal. Low 12 second car compared to low 13 second car stock vs. stock.
The car is an entire package meant to perform. Thats what the car does, in every single way. I've drove my dad's coupe hundreds of times. I still am amazed at how much of a beast this car is compared to his. If you want everything the Z can do, (accelration, and handling, and weigh a bit less) then your going to spend as much or more money on a coupe if you buy one for a few grand less. Then you still don't have a Z.
You still don't have firm feeling you get from FRC either, in a coupe.Now if your building a straight line only car, a cheap FRC is the way to go. But if your building a straight line car, buy a fbody.
RT
Every gear is shorter (including reverse) except for 4th (1:1 ratio)
BTW, ironexecutioner if you say that you searched and couldn't find the answer... that makes you a F#cking LIAR!!!! This topic has been covered countless times in the last year alone.... call me on it and I'll post the threads...
