Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Trans problem
Old Dec 3, 2007 | 03:50 PM
procsls6's Avatar
Default Trans problem
About three weeks ago I went out to a hang out spot to do some racing. I got a few races and on one of them it did not go into 3rd gear. It would grind pretty bad. I drove home and even on normal driving it would grind in gear. I never had a problem missing gears but I did start to have a problem going into 3rd or 4th. I thought it was the clutch. I spoke to Ranger before the trans thing and he said it sounds like the clutch was getting hot and making it hard to go in gear. We thought it was from how I launch(high rpm and a long ride of the clutch) But now it sounds like the trans. My questions are what usually happens when the trans goes and what usually happens when the clutch goes. Thought I would be able to get it covered under warranty from the dealer that I bought it from but after reading the fine print I know they will not cover it. It looks like I will be buying a new clutch and getting the trans fixed.
Old Dec 3, 2007 | 07:10 PM
pittman's Avatar
sounds like syncro's to me. I actually busted 6th on mine, would grind but still go in gear. Good luck. Pit-man
Old Dec 3, 2007 | 09:11 PM
procsls6's Avatar
Yea that's what I thought and that the samething mine is doing. Around I how much for you to get fixed. I got a few prices already just want to see if it is about right.
Old Dec 4, 2007 | 05:05 AM
pittman's Avatar
don't remember for just the trranny..was combined with clutch work for $3500
