Newbie C5 build budget ?'s
I am looking for a C5 this upcoming spring. I am looking at the early ones because I want money left over for mods.
My max budget is 30,000
I am looking at cars in the 17-18,000 range. It looks like I can get a pretty nice C5 for that with higher miles.
My wish list is shocks, sway bars and decent rotors, pads and SS lines and all poly bushings.
Engine wise I would love a L92 headed stroker long block from sdpc or TSP.
I have made an extensive parts list and calculated for every supporting mod I can think of like all the exhaust, new clutch, flywheel, slave cylinder, intake and tb, new water pump etc. Basicly all the crap I can think of to get it back running after a swap.
BTW I am a BMW Master mechanic with access to press, alignment rack all of my tools as well as my garage at home. Labor is FREE!
Do you guys think I could do all of the above for 30,000
Is there some big expense I have over looked because of my lack of knowledge about the Vette? Any high mileage items I should think of replacing / repairing. I know the seat bolstering wears though easily.
The rear will probably need to be beefed up a little with some hardened output shafts with that kind of power. Another option for you to consider is to buy a car that already has a lot of bolt ons and you can just use them after you build teh new motor, you may even find one with a built stroker in it already, but in the end this can save you a lot of money!
I have seen some cars for sale that already had a good set of headers and an exhaust that I would be ok with. That is a few 1000 off right there.
I am staying away from cars with built engines because #1 who knows who did what or how it was taken care of and #2 I don't want to pay a premium for some guys parts that I will not be using.
Dumb Ass Vette Moderator
Doing the labor yourself with save you a lot of money. If you look around you find a C5 that has some of the mods you want already installed, so you can save a bit more there. I definitely think you could all you want to do for $30K based on you will be doing the labor. One think to keep in mind is that if you are not very familiar with C5s or LS1, make sure to ask a lot of questions even if you think they might be simple and dumb.
Keith
Keith
Location: Somewhere Between Mild Insanity and Complete Psychosis
Lets see:
Used Coupe ~ 18,000
Coilovers ~ 1,700
Sways ~ 800
Brakes ~ 1,600
Headers ~ 1,500
Clutch ~ 1,200
Hardened Shaft ~ 300
Radiator w/ oil cooler ~ 800
Electric Water Pump ~ 540
AFR/TFS/ETP Heads ~ 2400
Cam & accessories ~ 800
z06 catback ~ 450
That puts you right at $30,000 and with top of the line suspension, 6 piston front brakes, top of the line clutch, hardened rear-end left shaft, top of the line radiator and oil cooler, top of the line 225cc heads so you can reuse them down the road with a 400+ cubic inch stroker bottom end. You should get over 450rwhp now with a good cam and top of the line heads.
Or you could go cheap on everything else and get a stroker now, but I really think in the long run setting up the car right first and then later getting a stroker you will be better served.
Plus 450rwhp in a c5 will be fun, then after a while when you start craving more you'll be ready to afford the big short block and the rest of the car will already be set up.
Used Coupe ~ 18,000
Coilovers ~ 1,700
Sways ~ 800
Brakes ~ 1,600
Headers ~ 1,500
Clutch ~ 1,200
z06 catback ~ 450
Lets see:
Used Coupe ~ 18,000
Coilovers ~ 1,700
Sways ~ 800
Brakes ~ 1,600
Headers ~ 1,500
Clutch ~ 1,200
z06 catback ~ 450
Used Coupe ~ 18,000
Coilovers ~ 1,700
Sways ~ 800
Brakes ~ 1,600
Headers ~ 1,500
Clutch ~ 1,200
z06 catback ~ 450
Used Coupe ~ 18,000 there in the 14-15 range with high miles, your changing everything so who cares about milage?
Coilovers ~ 1,700
Sways ~ 800 These 3 are nice, but no way necessary,
Brakes ~ 1,600 these cars handle and brake great in stock form
Headers ~ 1,500 Dont have to cost anywhere near that much
Clutch ~ 1,200 Dont scrimp here, pay up and get a good one the first time, 1200 should do it
Radiator w/ oil cooler ~ 800 Dont need this
Electric Water Pump ~ 540 I would never put this on my car, WAY to much electrical drain on a car that already has a weak charging system
AFR/TFS/ETP Heads ~ 2400 If i were you d just build a motor, As someone whos built a few BMW motor's in my day, LS1 motors are cake in comparison so you should be fine doing the work
z06 catback ~ 450 <--- Money well spent
The only reason mileage may be a concern is because of rock chips and stuff. Besides that you are correct. Everything would be re done.
Building my own engine instead of buying a long or short block is an option but when I tried to price that it seemed hard to beat the price of an already built unit.
dig around on Corvetteforum.com in the C5s for sale section...you should be able to do pretty darn well for the budget you have.
EDIT: I just had another idea....look around for a really high mile 2001 Z06 (Low $20s). Then you could leave the suspension alone and build the drivetrain only.
ha - too funny! budget and C5 don't work my friend
Seriously though, let me help out - you should buy one already modded. So what if someone else had the "fun" of waiting for months to get the right parts, chase down bugs like crazy, pull out hair and spend thousands of dollars? You can get it already done, and enjoy it right off the bat. Just make sure you have it thoroughly checked over. Just my .02!
I agree!! I bought my 99 FRC the way it is and dont regret it for a second. Just make sure it was all done by a reputable shop and tuned by someone that knows what their doing. My FRc had to have close to $60K in parts and labor into it and I bought it for half.
