Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 engine removal
Old Jul 9, 2003 | 08:39 PM
Progas's Avatar
Default C5 engine removal
Ok, who's been thru this. Out the top or bottom, pro's and con's
Old Jul 9, 2003 | 09:13 PM
Louis's Avatar
Default Re: C5 engine removal
The bottom is the fastest way. You will have a tougher time getting the inputshaft lined up from the top.
Pros from the top:
- no removal of Kframe
- no lift needed
Cons
- tough alignment
- 3 man job
-ABS gets in the way
out the bottom Pros-
-Fast
- easy stabbing the input shaft
- no hood removal
Cons-
-lift needed
-dolly for Kframe ( we have a special dolly for this sole purpose)
Hope that helps!
Louis
Old Jul 10, 2003 | 12:25 PM
Flyin'Brian's Avatar
Pulled mine out the top(with lift)and it was easy.
Did it all by my self too
Will do it again that way if needed.
Old Jul 12, 2003 | 08:37 PM
Dave F's Avatar
out the top seems OK, but would require removing the radiator, hoods, and maybe the nose and steering rack (maybe). I always drop everything out of the bottom.
Dave
