Z06 with MS4 dyno
Not too shabby cam only numbers. You should be proud of yourself. I'd like to see what she does with a set of Mamofied AFR 205's or even a set of TFS 215's. I'd take the AFR's as my first choice bro.
Congrats on your new numbers, now get her to the track. You got low 11's or even a 10.9 in your future.
from the cars I have seen get dynoed and what are some good setups. The trickflows are great. Then again I will be going with some ported and polished LS6 heads. Can't afford the big dollar heads, not when my clutch is going bye bye.
The tuner said I should get the LS2 tb ported and polished. That is holding the numbers down just a tiny little bit. If and when I do the clutch. I will get a set of ported and polished LS6 heads for her too. Then get a retune. Should get 450rwhp for sure.
