New combo
Here's the list of goodies:
Vengeance Racing Vindicator Cam
AFR 225 with 60cc chambers
Crane Gold Race 1.7 rockers
Ported FAST 92/RevXtreme 95 (Ron met me on his day off to port the snout of the FAST 92 to match the 95mm throttle body from RevXtreme)
New oil pump
Cloyes timing set
SLP underdrive pulley
Kooks 1.875" headers
Kooks 3" x-pipe
Stock titanium exhaust
With the help of some friends, it took one really long day and a few late nights to get it all done. Just a few small things to tend to now before it's back on the road.
Here is a video of it idling after a base tune and some minor tweaking to a base tune that I got from a local speed shop.
http://www.youtube.com/watch?v=DXGYdgUIutQ
I've spoken to Ron a few times, and I think I'm the first person to try the Vindicator with the AFR heads, so we'll see how what kind of results it's capable of. I'm just anxious to get all of the minor stuff taken care of so I can get it out on the road. I'm pretty sure the stock clutch isn't going to last for long once I start flogging on it!
Either way, I fully expect my stock clutch to hate life very, very soon!
Don't worry too much about the head volume in your combo, mine is 60cc as well...and my camshaft is just smaller than yours, and I still have the OEM water pump as well.
I think you will enjoy strong numbers and big power after a good tune.
Christian
Our cams are different in that I have more duration and you have more lift. Is your car a speed density tune or MAF, and did you tune it or have it done?
The MAF is out since a long time of my ZO6...
With my previous combo (~420RWHP-224 duration cam with 0 overlap) I did tune the car CLSD to begin and ended OLSD for the fun and fighting for fuel economy...
Honestly, no problem CLSD, I dialed in my VE table as close as possible and never noticed any trouble related to weather condition changes.
With my new combo and the noticeable overlap of my FTI StreetSweeper (almost the same as your Vindicator) I was not comfortable with my idle that I wanted as tame as possible.
I wanted firmly to avoid the looping situation, and if you read my threads you know how my engine is idling...this is done OLSD.
The OLSD helped my engine as well on the bucking situation (low load-low revs-low throttle opening) and with I would say a consequent amount of work on the VE table I am satisfied and very close to stock comportment with an already "big cam", the video about streetability is showing it.
Again, no problem with the weather condition changes now that my VE table is close to perfection.
Jeremy FORMATO did the dyno tune and the idle tuning.
Jeremy also took the time to set a very nice base line of my VE Table in ~ one hour of city driving, I did finish it.
Christian
Christian
With my IAT Sensor relocated in the Intake as shown in the pics below
I record from 43° at the lowest (that's really low in Florida) to 115° during city driving in August.
I will say my AFR is always looking close of the chart below (which are the values working with my combo):
Hope it helps
Christian
