Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Lower the Vette or Not?
Old May 2, 2008 | 10:15 AM
XtremeBBQ's Avatar
this is what you need:
http://www.eliteengineeringusa.com/Frame_rails.html
frame rails WITH built in pucks!
and these for the front:
http://www.customcorvetteaccessories...fattdaddy.html
Old May 2, 2008 | 10:19 AM
whatsgrip?'s Avatar
^^^ thats what ima need when I lower my car this Mon.
Old May 2, 2008 | 12:39 PM
Red99TA's Avatar
So this will just cause it to roll up onto a curb vice grinding those little frame extensions? I might pick up a pair since the previous owner DESTROYED those frame areas under the bumper. Speaking of which is there any way to fix that?
Old May 2, 2008 | 12:40 PM
DFWGrant's Avatar
I haven't had much luck finding a write-up on how to lower on stock bolts. Does anyone know of a good write-up?
Thanks.
Old May 2, 2008 | 04:27 PM
Red99TA's Avatar
Thanks.
http://www.z06vette.com/diy_lower.php
Old May 2, 2008 | 08:09 PM
XtremeBBQ's Avatar
i think the idea behind it is that it will pick your front end up over the incline long enough for your front tires to be able to touch and take over.
they also make mini rail guards on the front, but are made out of delrin which is a plastic, could pair those up with the rollers, and i dont think anything would be getting touched then, under any circumstance.
Old May 3, 2008 | 08:40 AM
BlownVette 2001's Avatar
Why would you lower your car to the point that it scrapes the ground ?
The front piece that you are slamming into everything supports your radiator and some other items.
Furthermore, you stand a good chance of cracking your rocker panels and fenders. The cost to repair the rocker panels is very high.
Old May 3, 2008 | 03:11 PM
XtremeBBQ's Avatar
well, you can scrape the ground on a stock ride height car.
and they arent going to protect anything from slamming into a risen piece of concrete, but will distribute the weight and not directlly harm the radiator rails. they arent made for a fix, they are just made to help not scratch up your car.
Old May 3, 2008 | 05:22 PM
pdd's Avatar
pdd
Originally Posted by O6DODGE
Do it I love mine lowered. when I look at other they just dont seem the same.
i agree
Old May 3, 2008 | 06:42 PM
I should post up up a picture of my bro's broken rockers on the FRC that he bought from being lowered to far and not having and rocker protectors. Both of his rockers are shattered and have to be replaced. Big bucks $$$.
Your fenders will be flapping if you hit in the wrong spots.
Old May 3, 2008 | 07:42 PM
XtremeBBQ's Avatar
that sucks.
how low was his FRC, thats hard to imagine since so many people have lowered vettes and you dont hear of to many problems.
must have been crazy low.
Old May 3, 2008 | 08:00 PM
  #32
bzettler83's Avatar
You just have to be aware of where you are driving... My car stock was pretty low... Just like I watch out for curbs so I dont damage my CCW 19's , I make sure not to go 30mph over speed bumps or go off road in my vette.
Old May 4, 2008 | 06:17 AM
  #33
that sucks.
It just hit wrong and shattered the rear portion of the rocker panel underneath.
It really depends on the angles that you hit (incline) going in and out of driveways or really bad roads that have ruts.
The yellow Z06 that we had earlier was so low that you could not drive it on some of the local roads that had ruts (i.e. center of roadway up and the two tire contact points lower).
I like the lowered look but if you're on the street, it's better to do a 19 / 20 package with taller tires to achieve that slammed look, then to lower your more than an inch on the stock size tires.
I'm going to be running 315 /18's on the front and 335 /18's on the rear of my project car that been in the works for about (4) years now. They are painting it now and then it'll come home and I have the interior and a bunch of wiring and a few mechanical items to sort out.
I'll probably leave the front spoiler off when I run on the street for fear that I'll bust it off.
The complete body kit is made of composite materials.
Old May 4, 2008 | 08:46 PM
  #34
matsarge's Avatar
mine's lowered on the stock bolts, plus a 1/3 of the bushing cut out in the back. I love the way it looks now.
Old May 4, 2008 | 09:40 PM
  #35
bzettler83's Avatar
we just lowered my boss's C6 and it still clears the car wash tracks.... Looks good and not too low... I wouldnt go lower than the stock bolts allow if you want to drive the car.
Old May 4, 2008 | 11:50 PM
  #36
XtremeBBQ's Avatar
car wash tracks?
Old May 6, 2008 | 07:38 PM
  #37
novajess1972's Avatar
car wash tracks?
I'm assuming he means when he takes it to the automatic carwashes that push your car along a track using automated wheels.
Old May 6, 2008 | 07:39 PM
  #38
This car is gorgeous!
