Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Question for myself. PIC'S******
Old Aug 29, 2008 | 06:55 PM
  #341
zo6 vett's Avatar
back to cars,
remember i have an 04 ls6,pvc is lke a ls2
i put a catch can in between the manafold pcv tube and tb.
i put a mini air filter seperator ,from harbor fieght ,from the vc to the left side charge tube.(3/8 nipple on tube)
oil breather on the oil fill tube.
does this seem right?
what did you guys do with blow by boost pressure in the motor?
i still need feed back on what to sell that stuff for
Old Aug 29, 2008 | 07:20 PM
  #342
sprayjunkie's Avatar
Originally Posted by zo6 vett
back to cars,
Can you clearly list everything you were looking to get rid of again?
Old Aug 29, 2008 | 09:06 PM
  #343
zo6 vett's Avatar
sure,
hpt pro 4credits remain/04 pcm with 2 bar lic.
inovate lm-1
lucas 42 #injectors
hardened left shaft
DEI #0101133 universal turbo insulation kit
i want to end up with 60# injectors/good used ok
stock pcm 04
wb controler for my O meter display
and enough cash to pay for the tune.they use efi live
i am going out tonight for a wot log.i am old i will be over 100% on the injectors.when i started this i was told 42's would carry 600whp with my set up.
tell me what you think,
mike
Old Aug 31, 2008 | 01:44 PM
  #344
sure,
inovate lm-1
lucas 42 #injectors
hardened left shaft
stock pcm 04
mike
We may well have interest in the LM-1, how much you looking for?
Is the left shaft brand new? How much for that?
Old Aug 31, 2008 | 03:03 PM
  #345
Oh, and as for the injectors, 600 rwhp is pushing it.
On V-Series' car with the Procharger at 7 psi we were at 85% duty cycle with 42s at 580 rwhp.
60#ers are the only option....
Old Aug 31, 2008 | 09:46 PM
  #346
zo6 vett's Avatar
shaft has under 30k and is in good condition,100.00
as for the lm1 250.00
hpt 500.00
42's 175.00
turbo insulation kit 75.00
all together is best .i will deal
on my last run they went 102% ,boost 6-7psi.still running lean.
580 would be cool with me,if i could just stop buying the next fix after fix.i just want it done
i wiil take on trade
wb control for my moats o meter
60's
mike
Old Sep 4, 2008 | 02:16 PM
  #347
zo6 vett's Avatar
i listed everything in parts fs under hp tuner+++++
mike
Old Sep 5, 2008 | 11:06 AM
  #348
V-seriesTech's Avatar
Is the LM1 the gage?...or is that the square box? I'm interested. Also interested in the shaft...pics?
hpt 500.00
42's 175.00
60's
mike
Old Sep 5, 2008 | 12:42 PM
  #349
zo6 vett's Avatar
click on my car and link to homepage /photo bucket.shaft(near the end) is shown.yes lm-1 is the box with cables,booklet and disk.all in the box
mike
Old Sep 6, 2008 | 08:23 PM
  #350
zo6 vett's Avatar
Wink WTF did i do to my car!
sold most of it,i'll make the date for a tune monday.
i traded for 60# fast injectors
sold the tuner
sold output shaft.
things are looking up
Old Sep 6, 2008 | 10:13 PM
  #351
sold the tuner
sold output shaft.
Sweet, keep us posted as to your tune results.
Good luck.
Old Sep 8, 2008 | 08:09 PM
  #352
update.
Decided to pull the turbos off, and have them jet hot coated. Also got some more heat foil coming in, as well as the rest of my fuel lines/fittings. Just gonna get all that stuff done before I bring it to the dyno. It was just too hot underneath the hood,...so, hopefully this ceramic coating and wrapping will help. My friend mike with his built G35,...just gave me an HKS EVS electronic boost controller. Pretty badass, and very nice. Looks brand new,....and it came with all the instructions. Going to swap the smaller waste gate springs in, and get it strapped down.
Hoerr racing's Jason and Dan hooked me up with my rails, and Miketurbo is doing the coatings on my hotside's. I have been looking for a turbo shop locally for a long long time.....and whadda ya know, I found one thats very close to a local hangout,...amonghst other unmentionable things. www.miketurboinc.com ......right there in front of me. Ended up being real cool people,...and close enough to home. Those should be done in the next couple of days. As soon as they are...the cars going right back together,...and crossing my fingers for some dyno time, and no car issues. My caddy is all messed up right now. So,...it's been aggrivating having two cars with issues.
Sorry for the delay,...i've been busy and **** happens. As always,..i'll keep you posted.
Old Sep 9, 2008 | 12:31 AM
  #353
BlownVette 2001's Avatar
Seems like the mods never end.
I'm wondering how hot it gets underneath w/front over the top mounted turbos ?
I would like to do a single front mounted turbo system as I am not looking for an all out system, just a system that will give me enough boost to hold my own.
Projects like these take a long time and lots of cash.
Old Sep 9, 2008 | 01:19 PM
  #354
allngn_c5's Avatar
Seems like she may never get done bro. As always good luck.
Old Sep 9, 2008 | 05:58 PM
  #355
Man, you ain't kiddin.
How hot does it get? Hotter then a witches tittie in a cast iron braw. Very hot. I have everything wrapped, turbo blanket and all. It seems like the HIGHEST heat area is right at the header/flange/collector area, where the turbo and header meet. My hood, has actually started to turn yellowish, right above on the outside only. So, I hope I can get rid of that discoloration. In the meantime, I just recieved my fittings for my fuel rails, and also my heat wrap. Had to do some stuff on a family members car today so, tomorrow i'll apply the heat foil.
A vented hood, would greatly reduce underhood temps. Greatly.
I'm willing to cut my hood but,.....just want it to look good,....and not get water logged if it has to be outside for a moment in the rain.
I didn't actually think this was gonna take this long. Who knows, by the time I am ready, to dyno it,...i'll be ready for a built bottom end and a bigger fuel system.
Then a tranny...then a diff....and then....
Old Sep 9, 2008 | 05:59 PM
  #356
....hoping for sometime in the next 20 or so years, i'll be done.
Old Sep 15, 2008 | 09:26 PM
  #357
VGLNTE1's Avatar
i feel your pain...........
Old Sep 16, 2008 | 07:15 PM
  #358
zo6 vett's Avatar
Default dyno
short note,
got back last night and drove it,WOW!!!
503 whp @5400rpm / 519 tq 5psi @3900rpm
mike
Old Sep 16, 2008 | 08:02 PM
  #359
VGLNTE1's Avatar
short note,
503 whp 519 tq 5psi @3900rpm
mike
you made 503 HP at 3900?
Old Sep 16, 2008 | 08:27 PM
  #360
aothepresident's Avatar
Just looking at this again, it makes me salivate and wish I had the know-how and funds to do projects like this. Keep up the good work man, it'll be well worth it
