Best Cam for stock 02 C5 Z06
We have used this Comp camshaft in a lot of builds with very good results. An automatic will need a stall converter but with a manual it is an excellent camshaft for everyday use. Bob
Description of COMPETITION CAMS 54-428-11
LS1/LS6 XTREME RPM HIGH XR281HR
Rpm operating range 2200-7200
228/230 .571/.573 112lsa
Hydraulic roller
High Rpm street strip camshaft for use with LS6 or aftermarket intake, Computer tuning required.
The XFI camshafts feature wider lobe separation for decreased overlap, yielding a more efficient combustion process. The XFI lobe profiles were designed to work in conjunction with recent valve train technology advancements, including COMP's Super Clean Beehive valve springs and increased ratio Pro Magnum rocker arms, thus delivering faster valve openings and closings while maintaining complete valve train control. Additionally, the XFI camshafts take advantage of the high velocity EFI-style cylinder head intake ports, intake manifolds and combustion chamber designs. The result: dramatic improvement in performance and durability for today's fuel injected engines.
Hydraulic roller
Where would I find a good white snake V3 package w/ all or most supportin mods? Im aware of upgrading oil pump, fuel pump, pushrods, springs, timing chain, intake + TB, lifters, heads, LT headers, 12 bolt read end, along with a possible gearing change? Anything in forgetting?
