Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Got picked on last night
Old Oct 10, 2008 | 11:42 AM
teddyca's Avatar
I do but I don't. I think the build quality of a Fbody is equal to a Mustang, I just perfer the looks of the fbody. I am in NO way bashing a Mustang. Hell I could have owned anything from the lineup, but when it came to spending $40K I could not justify it in an older stang. I looked at Roushe's and Cobra's, I just felt they were a step back from MY car. From a stock Z06 they ARE NOT but I have about $17k into my car since I bought it in January and just have a tough time parting. In any case it is not about me. PM sent to explain offline
Originally Posted by blown4.6
You make fun of the build quality of a mustang then say you would take an fbody? I guess I'm missing something.
To the OP 2nd gear at 55mph is your best bet.
Old Oct 10, 2008 | 12:48 PM
Z06.0's Avatar
i was just out driving and tried a 2nd gear punch at 55, its a whole different pull
Old Oct 10, 2008 | 12:56 PM
lemons12's Avatar
heavily modded..
Old Oct 10, 2008 | 01:01 PM
teddyca's Avatar
Heavily modded and driver error. Even a stock 02+ Z at those speeds is a handful. Youll learn young grasshopper. HAHA
Old Oct 10, 2008 | 01:09 PM
j0n's Avatar
j0n
I had the exact opposite experience a couple weeks ago. Came across a friend of a friend with a pullied 480whp cobra on the highway and went from a 55 punch. I was in 2nd but he only dropped to 3rd, the result was my bolt-on car embarrassing the **** out of him
Old Oct 10, 2008 | 05:57 PM
sslateron's Avatar
For a Cobra to pick on a Z06 thats just wrong. He must of had at least 450 whp to beat you. Maybe you both need your hearing checked. jk Don't feel too bad your learning still. You let him get the jump and you bogged the powerband in 3rd. This should be actually in the street section. Little more personal in the Vette section.
Old Oct 10, 2008 | 06:17 PM
RacerXLs1's Avatar
Now you no wat to do next time!!!
Old Oct 10, 2008 | 08:04 PM
chrisok1's Avatar
I have an 02 Z06 also, and definitely start in 2nd at 55 mph. Also, shift right before rev limiter at 6500. Even though the cobra had you in the HP, you weigh about 600 lbs less than he does and have better aerodynamics. You may have still gotten beat, but you would have at least given him a good run.
Good luck!
Old Oct 10, 2008 | 08:42 PM
Z06.0's Avatar
Hopefully I see him again.... I should go pick on a ricer to boost my esteem
Old Oct 10, 2008 | 08:49 PM
Z06PSI's Avatar
Fight fire with fire. Put your own twin screw on your Corvette.
Old Oct 10, 2008 | 08:56 PM
Z06.0's Avatar
how much does that set you back?
Old Oct 10, 2008 | 09:03 PM
  #32
Z06PSI's Avatar
About 8 grand with the basic setup. I am now adding a 383 stroker and a lot of other goodies so it closer to 20 grand but it will be worth it.
Old Oct 10, 2008 | 09:33 PM
  #33
Hennytime's Avatar
just put a 125 shot on the car, the outcome will be much different!
Old Oct 11, 2008 | 01:48 AM
  #34
sslateron's Avatar
Learn much you have. How to harness the power of the LSx.
Old Oct 11, 2008 | 01:52 AM
  #35
lemons12's Avatar
everyone on this website is an idiot..
Old Oct 11, 2008 | 02:13 AM
  #36
QUIKSILVERZ's Avatar
the lightning had to have a lot of mods. I just sold my 2000 lightning a few months ago. It had a 2.3 whipple, high-flow cats, catback, 3.73, ftvb, sct maf, injectors, pumps, and a good dyno tune. The truck was very quick esp from a stop. But from a 50-60 mph roll my 2002 c5z with a halltech would win but not by much. The lightning is heavy and made like a brick.
Old Oct 11, 2008 | 02:49 AM
  #37
BAD-GTO's Avatar
dude 55mph in 3rd is what killed u!!
like everyone has said already.....use 2nd next time at those speeds.
also....invest in the driver mod
Old Oct 11, 2008 | 10:02 AM
  #38
pittman's Avatar
That is a bad-azz motor and picture !!
Pitt
Old Oct 11, 2008 | 12:27 PM
  #39
davered00ss's Avatar
Moderator
A Zo6 should hang with a slightly modded 03/04 cobra. You should have been in 2nd at least to start.
Old Oct 11, 2008 | 01:34 PM
  #40
IdaGuy's Avatar
Originally Posted by Sigforty
I would have definitely tried in second as mentioned before. I have 3.90's in my car and from a 60-70 punch is where I would use 3rd. You want to be taching around 4500.
I second that. I have a 3.90 rear also, and it is good until 90 mph or so. Third gear with stock gearing must be good to 110+? That's a long pull from 60 mph.
