Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Got picked on last night
Old Oct 11, 2008 | 03:20 PM
  #41
Z06PSI's Avatar
Originally Posted by pittman
That is a bad-azz motor and picture !!
Pitt
Thanks! Just wait for the next iteration. Should be done in the next couple of weeks.
Old Oct 12, 2008 | 11:26 AM
  #42
Z06.0's Avatar
working on the driver md, once im in 2nd should i just floor it at the 3rd honk or clutch in build rpms and let it out/floor it?
Old Oct 12, 2008 | 02:18 PM
  #43
blown4.6's Avatar
Most definitely have it in second with the clutch out so you can quickly floor it.
Old Oct 12, 2008 | 03:02 PM
  #44
00T/AWS6's Avatar
yeah i just raced someone not to long ago at about 50-55 in 2nd. It's definitly high up there in RPM's so you just have it in gear and on third honk floor it and shift to third when need be. You think hearing honks is hard now, wait till ure at 55 in 2nd with full exhaust it gets quite difficult. haha.
Old Oct 12, 2008 | 03:34 PM
  #45
sslateron's Avatar
It just so you can get the car to lunge forward, then nail 3rd. Maybe you want to invest in a Short throw shifter with a pistol grip shift ***. lol
Old Oct 12, 2008 | 03:40 PM
  #46
Z06.0's Avatar
na i want a punchy but it only comes in a 5/16 thread
Old Oct 12, 2008 | 11:21 PM
  #47
blown4.6's Avatar
Haha that would be a badass shift ****.
Old Oct 13, 2008 | 11:10 AM
  #48
scramblerman's Avatar
second gear at 55mph roll. Go and drive the car. Run it in third at 55mph, then run it in second at 55mph. Huge difference!
Old Oct 13, 2008 | 11:17 AM
  #49
already have the car in the gear it should be in with your foot off the clutch. Soon as you hear the third honk, not at the end of the honk but as soon as you hear it, you mash the gas and get ready to shift into third. Get a nice short throw shifter like the guys have been saying, that way the 2nd to third shift is like butter and you can never miss.
I love the bpp short throw shifter short throw than a pro 5.0+lou's short stick in a f-body, if you came from an f-body. The shifter is adjustable so you can put the handle where you want it to best suit your needs. Other shifters like kirban and hurst are pretty good as well. The stocker sucks!
http://www.breathlessperformance.com...ts/100-262.asp
If you have a username on the corvette forumyou can get a 10% discount on the products.
Just go out and drive the car and try some of the tips the guys have been saying. Not too hard, just need to get used to it.
Old Oct 13, 2008 | 11:21 AM
  #50
Originally Posted by IdaGuy
I second that. I have a 3.90 rear also, and it is good until 90 mph or so. Third gear with stock gearing must be good to 110+? That's a long pull from 60 mph.
with stock gearing it is good to about 95-98mph, can't be exact though. I was shifting before 100mph though into 4th on my Z. With my cam I am closer to 110mph now when shifting into 4th at around 7000rpms.
Old Oct 13, 2008 | 11:24 AM
  #51
if there is enough steel, just drill the hole bigger and re-tap the threads.
Old Oct 13, 2008 | 11:29 AM
  #52
Kenne bell=sick car!
http://www.youtube.com/watch?v=gLBHsFYsIck
for those of you not wanting to go through to find out what his car has:
AMERICANHP-This is my personal car. Its got an LS2 403 cid motor. This run was made at 16psi. It make right around 802rwhp, and 851rwtq SAE. The car made just under 800rwtq right around 1900 rpms, and carried over 800rwtq from just over 2000rpms to just over 5200rpms if memory serves me right. Mashing the pedal, is like spraying a 400shot single stage of nitrous. It hits HARD!!!!
Old Oct 13, 2008 | 01:16 PM
  #53
Z06.0's Avatar
Im thinking about it scramblerman shouldnt be too hard to drill. And ive already gone out and seen the difference from a 2nd gear/3rd gear pull. I just want my rematch
Old Oct 13, 2008 | 01:40 PM
  #54
blown4.6's Avatar
I dont see that car getting any sort of traction.
Old Oct 13, 2008 | 01:44 PM
  #55
Azrael's Avatar
Originally Posted by davered00ss
A Zo6 should hang with a slightly modded 03/04 cobra. You should have been in 2nd at least to start.
I agree, I personally have seen a stock C5 Z06 pull a pullied Cobra... From a distance that is...
Of course I think the Z driver was the better driver... Although I know the Z driver fairly well...
Old Oct 13, 2008 | 02:11 PM
  #56
1bigcamdls6's Avatar
z06.0 ur in middletown u need to come down to dover...but first put a cam in that z06...and def. run in 2nd gear...damn 55mph in 3rd?!?! no wonder bro
Old Oct 15, 2008 | 08:58 AM
  #57
Z06.0's Avatar
id like h/c/i but first comes the vararam and lts
but i also have the truck which needs a little tlc. Im thinking about messing with it first because the list is way shorter lol
Old Oct 15, 2008 | 11:06 AM
  #58
blown4.6's Avatar
Vette first truck later
Old Oct 15, 2008 | 12:08 PM
  #59
Z06.0's Avatar
lol the truck list is small
cai
lts(when available)
ranchhands front,back
20s w/ 33x13.50
air bags
and tune
Old Oct 15, 2008 | 04:53 PM
  #60
z06.0 did u do u do any of ur own work? if u need some help i can do alot to that car i did all of my stuff except cam install...heads were a BITCH!! also except for tune i had put nitrous in at one time but never sprayed cause of all these mods plus nos+ls6 clutch=no no...stuck on side of road. but intake and headers are pretty easy so is intake manifold and catback...my car is currently sans catback which makes it unbearably loud and im afraid im doing damage to rings without catback
