how to tell if i blow threw the clutch
Old 04-18-2009, 09:41 AM
bad6as's Avatar
Default how to tell if i blow threw the clutch
went to the track last night and could only get mid 1.7 60fts leaving at 4 and nitrous coming in same time. its a ls7 clutch at aprox 550rwhp 3.90 gear 3650 race weight. m/t et street 13 psi.
on one pass if felt like the shift light stayed on for a lil longer
i could do 5k dumps n/a and get 1.69's
Old 04-20-2009, 12:38 PM
BigKap94z's Avatar
At that weight, power and rpm i would most certainly assume its slipping. Usually once it starts slipping even if in higher rpms your fluid will get discolored and degrade....often leading to pedal issues. Do you have any of that?
Quick Reply: how to tell if i blow threw the clutch
