A little disapointed what do you guys think?
Old 09-13-2009, 11:24 PM
TRUCKIN's Avatar
Default A little disapointed what do you guys think?
I have a 97 lt1 convertable with 115K. It has stock heads with mild port work. .579int .583 exhaust. 30# injectors. Long tubes no cats. 3200 converter. Stock maf and throttle body
I had the stock 2.73 gear and ran through the full exhaust and went 13.17@106.
Now I went back today with a 3.73 new suspension in the rear and on closed exhaust and slicks ran 13.06@ 104
Then I ran it open exhaust and got it to run 12.71@107
Now I dont get it the 60ft was the same as as it was with the 2.73 which was 1.80.
I had no mph at all. What do you guys think. I figured it would have ran more mph and at least 2 tenths faster.
The car weighs 3800# with me in it.
Thanks for any input on my set up or advise
Old 09-14-2009, 06:46 AM
69LT1Bird's Avatar
What kind of realistic horsepower do you think you have?
Old 09-14-2009, 09:26 AM
TRUCKIN's Avatar
Some where in the high 300 range. Im more disapointed that the gear change didnt do anything but pick up one tenth and lost 2 mph. I cant really look at the open exhaust run cause I never ran it like that with the old gear.
Old 09-14-2009, 09:34 AM
JeaneZ28's Avatar
How many passes did you run with the closed exhaust and 3.73.
Old 09-14-2009, 10:34 AM
TRUCKIN's Avatar
I ran 2 passes. The other pass on the closed exhaust was 13.16@ 102. I trailered the car also so it wasnt heat soaked from the drive to the track.
Quick Reply: A little disapointed what do you guys think?
