Why is my car so SLOW!
Old 10-11-2009, 05:23 PM
lemons12's Avatar
Originally Posted by violent_celerity
my buddies formula with a lid, headers, and stock exhaust was running 13.20's at speedworld which is very similar DA.
How do you know what the DA was?
DA of a track chances all the time.
Old 10-11-2009, 06:00 PM
violent_celerity's Avatar
true but theyre about 40-50 miles apart.. temperatures can vary by 10 or so degrees around phoenix, but not enough to make a car with more mods run a second slower than a near stock car. somethings fishy with the OP's car.
firebirds DA at around 4pm oct 10th:3360
Speedworlds DA around 4pm oct 10th:4578
my friend ran around 10 pm with the DA was 2885 at speedworld.. granted its alot better than 3360, but depending on when the OP ran id assume they were withing 500 feet of eachother.
Old 10-11-2009, 06:08 PM
brock87's Avatar
I had a similar prob it was my mass air meter.
Old 10-11-2009, 06:09 PM
fccs's Avatar
The DA is pretty high at my track and I ran a 14.0 stock at 101-103 I was trapping with a 2.3 60ft best. After headers and exhaust I still ran a 14.0 but trapped around 106-109 this time. Something seems off, if your 60ft sucked or your trap was higher it would seem normal but idk
Old 10-11-2009, 07:24 PM
ACLR8R's Avatar
Something to think about, I still have a hard time blaming the tune. A car with a stock tune should still trap as high or higher than me. When we put the factory tune back in it dropped 3-5 mph, which tells me its doing something.
I need to see if I can get it data logged, and see exactly whats going on.
Old 10-13-2009, 04:29 PM
ACLR8R's Avatar
Well I got done putting an intake gasket and an alternator on the buick, and decided to screw around with the Camaro.
My brother said I should try pulling the MAF connector and seeing how it acted. Pulled it and wow, what a difference. It went from laying 3-5 ft of rubber in first to pretty much all of first gear.
I would assume I need a MAF
Old 10-13-2009, 09:15 PM
AutoRoc's Avatar
nice find
Old 10-13-2009, 10:15 PM
therealcreeper's Avatar
try just cleaning it first. a can of MAF cleaner is only $5 and may save you from having to buy a whole new one.
Old 10-14-2009, 09:51 AM
ACLR8R's Avatar
^^^ I have some, I'll give it a try today.
Old 10-14-2009, 10:04 AM
bjamick's Avatar
Check the wires on the MAF, if any of them are messed up in anyway it will make the car run like poo. You can try and clean it first though, but it still may be in the tune, bc what you did by unplugging it was send it into SD.
Old 10-18-2009, 10:01 PM
ACLR8R's Avatar
Cleaned it and it runs good, still. It was really dirty! Took about 5 q-tips to get it all off, but much better now!
Thanks
Old 10-19-2009, 09:08 AM
  #32
79TAKid's Avatar
Originally Posted by custm2500
I have seen someone turned there fans on for a run and lost alot of time. I don't remember numbers but it was .75 I think. Maybe with your fans set cool they are running and drawing amperage and messing with airflow.
I have my fans on everytime the car is on. It doesn't slow it down.
Quick Reply: Why is my car so SLOW!
