Cam only na m6 10.842 @ 127.5
Yup, the truetrac with ring gear is really heavy 57.5. I almost couldn't catch it when it came out off the lift last year when I put the 430s in at newera. Then when I pulled it in the garage at my parents on jackstands, it was hard to do lower it to the ground nice on your back. I'll see if I can zoom in on ant pics I took, I weight ther spool on the N20 scale at newera when I put the ring gear on the spool and used the press to put the bearings on it. And wrote with a shapie on the side spool. but off the listed weights is was 32.8#s really.
Congrats to both you and Rob on your new PBs!!! I've been fallowing both of your cars for a while now. Hopefully I'll be running with you guys next year with a bigger cam and a little more weight reduction.
#32
A/C stuff (Compressor, condensor, accumulator, lines)
AIR/EGR
Stereo (Head unit, amp, speakers)
Steering wheel and airbag (Replaced with MOMO)
Drivers seat (Replaced with a Corbeau)
Pass., rear seats, and belts
Insulation
ABS
TC/Cruise
Front and rear bumper supports
Spare tire/Jack
Spintech muffler w/mufflex tailpipe removed at the track
Billet Streetlites
#33
I'm not sure on my exact weight. I need to weigh it next time I'm at the track. My problem is that I don't want to cut the car up. I want to be able to return it to stock. My weight ruduction list includes.
Insulation
ABS
TC/Cruise
Billet Streetlites
Insulation
ABS
TC/Cruise
Billet Streetlites
#34
AIR/EGR
Insulation
ABS
TC/Cruise
Spare tire/Jack
Billet Streetlites
AIR/EGR
Insulation
ABS
TC/Cruise
Spare tire/Jack
Billet Streetlites
#38
Good job you're flying. I'm always following these post and have always wanted to try it.
I'll be taking a shot at it next year with a Jerico behind it. I'm buying a brand new gm longblock. I'll prolly do a custom cam and give it a shot. Can't wait!
