Quickest Stock Internal M6 LS1?
Mine has slowed down alot due to the problem i have had no luck in figuring out. It runs decent when i don't power shift but when i power shift it shows going pig rich on my wideband. I am getting closer to figuring it out tho. My car weighs a good bit more now but i still mph at 115 without power shifting in the heat.
Oh yeah I remember you saying that. It bogs right after you shift right? Mine did exactly the same thing, slowed me down about .2 and 3mph. I have no idea how i fixed it but I'm pretty sure it was something in the tune.
Have you been able to get to the track any?
Yeah I don't know what I did but I had a shop tune and they couldn't fix the problem so I started from scratch and did my own and the problem went away immediately, dropped .2 in the 1/4 too...
I haven't hit the track yet, still need to put my hood on and retune it. I've only been in town a few days at a time and haven't had time to mess with it.
You should be able to beat 11.42 with all the stuff youve done when you get a chance to run it. Mine's gonna take some really cold weather with all the weight i got in it now.
I am shooting to run in the 11:50's my self with my automatic. I am close. I ran 11.623 last year and will be running soon before the cold weather goes away. With a little tuning I believe my car will run in the 11:50's. If you need any details I have done to my car I will be glad to share with you.
Your the second person i have found that has the problem very similar to mine and it be in the tune. I am gonna mess with the tune this weekend and see if i can fix it.
#38
No times yet. We are both trying for 11's with pretty similar setups.
black and pinks:
fast 92/92
pacesetter 1 3/4
dana s60 4.30 with 28 9.5 15 toyo slick
full umi suspension minus kmember/a-arms
strange singles front
comp eng. rear (ftm double stranges as soon as money permits)
mine:
vic jr setup
texas speed 1 7/8
udp
9" 4.11 with 26 11.5 15 et street
Unsure on weights atm havent gotten either scaled but his is alot lighter than mine. Last year mine had run 12.5 @ 110 spinning with little qtps on stock rims. Hoping with all the changes this winter both cars can make it at least 11.8 and work from there.
black and pinks:
fast 92/92
pacesetter 1 3/4
mine:
vic jr setup
texas speed 1 7/8
udp
#39
black and pinks:
fast 92/92
pacesetter 1 3/4
mine:
vic jr setup
texas speed 1 7/8
udp
black and pinks:
fast 92/92
pacesetter 1 3/4
mine:
vic jr setup
texas speed 1 7/8
udp
after setting my best time with a/c and ftra,my plan was to try no a/c and the cris1313 ram air,its definetly a better setup,good luck to yall.
ps get rid of the et street
#40
the a/c is out off my car and I do have a little weight pulled out off my car and its a hard top car too
I do have fast toys 98mm lid and slp 85mm mif and a texas drivetrain diamond clutch leave 3
