MS4 cam and supporting mods...what shoud it run?
Recently did the heads and cam swap in my 02 ss camaro.Installed the Ms4 cam,stage 1 prc ported Ls6 heads from texas speed,4000 stall,lt headers,ory and a lid. Car was dyno-tuned by Speed inc.Made 406.7 hp at 6300rpm.
Ran it a couple weeks ago...12.1 at 111 mph. Not the e.t. I was looking for,expected to be in the high 11's at least,but that time was run on the stock 3.23 gear.
This past week a put in a set of 4.10's and had the speedo and shift points re-calibrated. Going to run it one last time tomorrow. It's supposed to be in the high 50's up here in northern Illinois.
What time should I expect to see?
Forgot to mention, MT ET Streets at 15psi. in the rear.
I write checks with my mouth that my ass can't cash
i dont know how much weight reduction you have, but i have 100 less horse and am runnin 11.76, so u should be in the tens in my opinion if everything is working correctly..
60 ft was 1.75. convertor is a 4000 vigalante. Haven't weighed the car, but it's safe to say that it is close to stock factory weight.No weight reductions have been attempted. I do agree,the trap speed is way too low for what I've done.
deffinetly something wrong...60 isint great but u can always improve, but the trap is way low i would start looking for problems, and calculate driveline slippage because id bet ur third gear clutchpack is fried. what was the 8th mile? is this a stock tranny ? if so spinnin a stock tranny to 7 grand which is probly what you are doing will kill it in no time...
1/8 was 7.74.
[QUOTE=blwn_00gt;14087136]i ran a 11.40@117 with a 224/230 cam, long tubes, 3200 vig, tuned, with 3.23 gears and stock 241 heads. only weight reduction was big and littles...[/QUOTe
Thanks for the reply. Everybody I talked to said the 3.23 was what was killing my e.t's and trap speed's with the ms4.From what I gathered the ms4 needs atleast a 3.73 in a A4 to come alive.
Maybe I should've went with a smaller cam on my stock 346 LS1.
my 2002 WS6 was run 11.3 with this set up 90/90 fast, ASP UD pulley, 1-3/4 headers, cut-out, MS4-111 , 243 patriot stg3 heads, full weight, 4000 stall, 373's
when it was cam only MS4 with stock 241 heads i was run 11.6
Maybe I'm not launching it right and need some more track time with the car.
Thanks for all the replies and information. I'm going to go run the car tomorrow for the first time with the 4.10's...Really hope that helps out with my e.t.
[QUOTE=importhater81;14087196] i put the ms4 in a 00 ta i had with a pt4400, it had 3.42's when i got it and after the cam and stall swap i changed to the 4.10's and the car felt alot better. wish i would of ran it once or twice atleast before i sold it..lol
stock tranny is ur problem, you cant spin a stock tranny over like 6200....i had mine shifting at 6200 (just barly bumped up from stock) and was bleeding off line pressure from the weak pump slide spring and was burning up my 3rd gear clutch pack...when i got my tranny built they put the z pac in it and all the good stuff adn now it shifts perfect at 6300....id bet your 3rd gear clutches are fried and you need a good transmission since ur probly shifting that thing at like 6900....hell no dont kick urself for going to big just get the bugs worked out and run tens like ur suposed to !
I'll post my results with the 4.10 gear when I get back tomorrow.
Was on phone before, I can give a more detailed response now.
The thing about the "donkey dick" cams.. Everyone wants to get them but does not want to sacrifice driveability or the spend the money on good flowing parts.
For instance... They don't want 410s/4400 converter/good flowing heads/FAST/etc etc etc..
The big cams are good cams you just have to compliment them with the right parts, which in a DD, is sometimes a pain.
The 410s will definitely wake it up.. However, it should be KILLING anything.
You can't just go off mine and other peoples times... That is NO indication of what you should be running (only knowing that small amount of information).
First off, what kind of DA are you running in?
Mine was in 2000+ (give or take a few).. My car was quite a bit liter than yours though and I had a FAST intake. Makes a difference..
I doubt it is the launch.. Just play with it some, leave at idle/leave at 1100 RPMS/leave at 2500 RPMS/leave right before the tires start to break. ALL cars like leaving different.
I had 115K+ miles on my car with a 4000-4400 converter/410s/H/C/full bolt ons/etc etc and cut 1.5 60' cam only and 1.6 H/C spinning... Shifting at 6200 cam only and around 6350-6400 H/C. Never had a problem.
Of course though, a built trans won't hurt anything!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Results with the 4.10....11.85 at 115 mph with a 1.65 60ft. Still think I'm leaving some on the table, but time to put it away for the winter and fine tune it.
Not sure what the D.A. is at Byron dragway.I'm sure it's not that much above sea-level.
Thanks again to everybody for your input and advise.
