Vig 3600 to CircleD 5C....Possible Gains??
1 Post
I'm going to be switching to a CircleD 5C (4000-4200) from a PI3600 and I would like anyones guess on possible gains. Background information on the car is: 2001 Camaro, LS1 stock short block, PRC 2.5 Heads, MS3, Ported 92mm FAST, 12-Bolt w/4.10's and weighs 3250 with a driver. Currently the car has run the best of 11.01@123 (7.0@97) in the 1/4 and recently after some changes runs 6.80's@99-100 (haven't run it in the 1/4 yet). The car ran 6.80's 4 times in a row with a 1.47 60' foot so I would say it's consistant. Right now the current converter flashes to 3500 from what I can see in my logs and goes from 6600 down to 5000 when it shifts. I believe when I spoke to Chris about the 5C he stated that it should flash to around 4200 and hit hard. I'm just wanting a guess on gains in the 60' and 1/4 mile. Thanks!
i just got the same converter, we have about the same specs, the only diff is I am living on the edge with the stock 10 bolt and axles with 373 gears.. I want to see what kind of responce you get from the pros...
1 Post
Yeah, I'm curious also and I know the car is going to pick up but I don't know how much. For how small the current converter is it sure seems to 60' well. That's why I checked my logs because I thought it might have been flashing higher than expected. If you look at the fastest people with MS3's all of them have a 4000+ stall, so I figure I'm heading in the right direction. If it dips in the 1.3 60's I'd be very happy.
1 Post
That's the way I'm headed right now because since my last runs I've taken 95-100 pounds out of the car. Hopefully I can find some more cheap weight to take out of the car.
1 Post
OMG! Your sig had me laughing for 5 minutes. Thanks for the compliments, I really like the Vig I have now but it just doesn't fit my setup. The converter has been in the car a couple of years and I spec'd it for a stock motor with spray. I thought I could get away with it being smaller but it's tighter than what I want. I'll probably keep it laying around just in case I put the nitrous back on the car. Anyways, I will keep everyone updated on the gains.
I run a Circle D 4C in my LT1 car and it does hit very hard. I was cutting 1.42's 60ft at the LTX shootout and was very happy with the way their converter performed. I'm hoping there is some room to bump up the rpms on my converter looking for some 1.3's also.
