New Best.Full weight m6 SS. Need cage...barely
Old 10-23-2011, 12:39 PM
big dave's Avatar
Default New Best.Full weight m6 SS. Need cage...barely
After all the problems I've had with my clutch over the past year, it looks like it's all coming together at the right time. My new best went like this.
60' ...1.695
330'...4.805
1/8....7.38 @ 95.32
1k......9.60
1/4.....11.47 @ 121.66
http://youtu.be/BCJNFJrp2lg
I'm now hoping that a change to 26" tires may give me a little more mph and possibly a 11.3? timeslip. Honestly, I was hoping to get an 11.4 at full weight before the year was out, I didn't expect it to come so soon. All this with a stock 154k mile bottom end. Long live the ls!!!!!!!
Old 10-23-2011, 02:53 PM
BADD SS's Avatar
60' ...1.695
330'...4.805
1/8....7.38 @ 95.32
1k......9.60
any video's? did it spin on the launch, what rpm did you launch at?
Old 10-23-2011, 03:38 PM
big dave's Avatar
I was around 4k at launch. I detected a little spin but never lifted.
Old 10-23-2011, 03:50 PM
msydow's Avatar
i cant wait to get my driveshaft and drag radials. whats your set up?
Old 10-23-2011, 04:12 PM
BADD SS's Avatar
Should launch higher... You want to spin
Old 10-23-2011, 04:52 PM
big dave's Avatar
I don't think the clutch will take a much higher rpm launch. I'll try it next week though. I'd really like to try the skinnies I took off my lt1 car but for some reason they won't fit. My guess is they should be worth around .06
Old 10-23-2011, 06:27 PM
BADD SS's Avatar
What clutch?
When I was close to full weight, with patriot stage 1's and a torquer II, 418 rwhp, I went 11.36 @ 120.5
1.57 60'
So you definately should be able to better that in good air.
I was launching at 6200 then, spun about 15 ft, wheel speed stayed up and it went well.. Clutch did not like it, but a monster level 3 will take that all day, and it did well, I cut 1.42's with 430 rwhp on it.
And the skinnies should net close to .10
Old 10-23-2011, 06:50 PM
25thhawk's Avatar
Congrats on the times.
I gotta agree on the clutch. Im using a monster stage 3. I really didn't like it much until I took it to the track. It chattered bad, was a real bitch to drive. A couple good hits, and now it is perfect, no chatter, real nice. Got 20 passes on it and it seems to love the abuse, no smell, no nothing. Its great.
Ryan
Old 10-24-2011, 04:16 AM
big dave's Avatar
I'm running a twin disc Mcleod clutch. I don't think the car will sustain a 5k rpm launch. Are you guys dumping the clutch or allowing it to slip a bit?
Old 10-24-2011, 08:11 AM
25thhawk's Avatar
Mine seems to work best with a fast release instead of a clutch dump. The dump seems to hit the tires too hard and spin them a little too much. But I think that is all in the suspension. I'm sure if I changed the shocks alittle, the dump would be fine.
Old 10-24-2011, 07:01 PM
Hardtop's Avatar
Good run Dave. Are you going with 26" slicks.
Old 10-24-2011, 10:32 PM
big dave's Avatar
Thanks Bruce. I'd like to try the 26" tires again, but that run was on the 27". I am still hoping for more mph so I may have to try to get the skinnies to fit.
Old 11-14-2011, 09:10 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
BTW, you only need a 5 point roll bar for 11.50 to 10.00. No need for a cage until 135 mph or single digits...
Derek
Old 11-15-2011, 01:37 PM
98TADRIVER's Avatar
Derek
lol I was gonna say the same thing
Old 11-15-2011, 02:21 PM
ROMERO98Z28's Avatar
Good run!
Old 11-16-2011, 05:09 PM
big dave's Avatar
lol. I did mean roll bar. It's all the same to me... either way, the road stops here. I'm not planning on going any faster.
Old 12-09-2011, 03:40 PM
GTP231's Avatar
Awesome time Dave!!!! Is this still on the 10 dolt?
The skinnies usually clear with a 5/16" spacer iirc
Old 12-09-2011, 09:22 PM
studderin's Avatar
nice times
I have a RXT twin. I do a fast slip on 275DR 5800-6000 gest high 1.4s. ETdrag faster (slow dump) 6500. its fine.
Old 12-10-2011, 05:13 PM
1Bad97WS-6's Avatar
Congrats man and ya like said above a skinny should fit with a 5/16 spacer without grinding or get wheels that don't require any grinding..
Old 12-11-2011, 02:22 AM
big dave's Avatar
Originally Posted by GTP231
Awesome time Dave!!!! Is this still on the 10 dolt? The skinnies usually clear with a 5/16" spacer iirc
Thanks. No more 10 bolt, I took the 12 bolt out of the lt1.
Originally Posted by studderin
nice times
What are you running for suspension?
The 5/16 won't work and I grinded the hell out of one caliper before deciding to quit.
I did get another new best of 11.23 @ 124.2 today with the 17s in front and MT et streets out back. The only other weight reduction done was the spare/jack delete, and the front sway bar removal. Raceweight was probably around 3640.
Quick Reply: New Best.Full weight m6 SS. Need cage...barely
