Fastest 4L60E E.T. "RECORD"
When you say 4L60 do you mean still as a 4 speed (with overdrive etc.) or one of the special 'overdrive removed' (aka: 3L60) type of builds?
Or either one?
Not sure about the whole list but I believe that this guy still holds the overall best:
https://ls1tech.com/forums/canadian-...8-8-160-a.html
Or either one?
There isn't a list that I know of. Arun still has the record with the 8.81@160mph. It is a fully functioning 4 speed 4L60e with a lockup torque converter. We are working on an LSX All Motor class C5 for a customer right now that should drop the record even lower into the 8s.
is this for full body cars only!!! i,ll try and find it bit of sure a year or so ago a guy in australia in a cammed ls1 4l60e went low/ mid 8s in a dragster type setup!!! less weight obviously helps!!! well done to all those running good numbers !!could only get mine in the low 10s in a 4050pd car before destroying it!!!gave up and went t400!!!cheers
