Almost stock 2001 SS first passes
First time at the track with my camaro. My goal was at least a 13.99@100+ and I got it on my first run so I was happy. Best 60' was a 2.277 and that was a bog down to 2k so I know I couldve done better but all in all I was happy. 13.79@104 isn't bad at all for a high mileage pretty much stock camaro.
2001 camaro ss m6
Mods:
164k miles
275/40/18 mismatched tires
slp lid
muffler delete
slipping clutch (on launch)
2001 camaro ss m6
Mods:
164k miles
slp lid
muffler delete
Mileage doesn't mean as much as people think it does to these LS engines. If it were a small block chevy from the 70's then it would be a little different issue. The clutch and tires are your biggest issue but seeing as how your goal was a 13.99 then that tells me you are more interested in cruising than having a drag car.
I trust a good running high miles unopened engine over most rebuilds , and plenty of "builds"
Get some more seat time... on a 2.1 60ft I went 13.1 @ 108 bone stock (245/50R16 GYE RSAs) Just need a nice and smooth launch and the results will likely surprise you. I am not even a good driver...
The next spring my wife pulled of a 13.1 @ 106...
Surely if my Z28 can do it your SS should be more than capable.
Had nothing better to do so I went back to the track with longtubes/ catted y pipe added. Best run was a 13.3@107.5. Had to shift slow due to my stock hydraulics getting tired. Got locked out of 4th half my runs. And if i shift fast my clutch slipped. Got the 60 down a hair still room for improvement there. 2.23. Did a 13.4@93 when i was locked out and that wouldve been my best run 8.6@86.7 was my 1/8.
