Brian Tooley cam, stock LS1 241s, 150 shot - 10.54 @ 129
Brian Tooley Racing Cam (235/242 .620/.594 111 LSA)
BTR .660 lift valve springs w/ titanium retainers
Chromoly pushrods
Comp Cams Rocker Arm Trunnion kit
FAST 90/90
85 mm MAF
98 mm Lid
42 lb injectors
u/d pulley
Racetronix fuel pump kit
LS6 oil pump
single roller timing chain
Nitrous Outlet 2 stage 90 mm plate
Lingenfelter 2 step
I still have some tweaks to get the 60' back down into the 1.4 range like I was previously going. I'll be sending the converter over to Greg at FTI to loosen it up a bit. I believe the car is dropping rpm on the launch and not fully activating the nitrous on the hit. I've only made 5 passes on the new setup but I'm pleased with the results so far. These passes were in 1900+ DA and 130+ track temps. She's definitely pulling nice on the top end.
![](http://i1276.photobucket.com/albums/y480/J_Rod135/IMG_43071_zpsa03cbf7f.jpg)
Chromoly pushrods
FAST 90/90
85 mm MAF
98 mm Lid
42 lb injectors
u/d pulley
LS6 oil pump
Lingenfelter 2 step
