new pb on 100 shot
Old 04-11-2014 | 11:58 PM
TravisMcGill2000's Avatar
Default new pb on 100 shot
Went 6.52@103 1.39 60ft all on stock 10 bolt with 3.42 gears. Da was 1400 and was pullin 6 degrees of timing. Only made 2 passes on spray. Went 6.7s@ 100 on the other pass. Thay was on 50 shot. Ill try get video up soon.
Old 04-12-2014 | 12:31 AM
Old 04-12-2014 | 12:39 AM
HCI2000SS's Avatar
Nice! What do you make for power?
Old 04-12-2014 | 12:49 AM
Thanks. Never had it on the dyno. Just had it street tuned and reading plugs
Old 04-22-2014 | 11:02 AM
FlatBlackZ28's Avatar
You are hauling! With our setups being almost identical, I'm excited to hit the track and see what happens!
Old 04-22-2014 | 02:21 PM
Thanks man. You need hurry up and get it to the track. Im very happy with the result so far. Its still got lot left in it on 100 shot. Needs more timing, gear and tweak the tune. Need to be turned about 7200 also.
Old 04-22-2014 | 03:17 PM
LS1rob00's Avatar
Nice, that's solid...especially for a 1400 DA.
Can't believe you pulled a 1.39 on a stock 10 Bolt lol. That thing must hate you.
Old 04-22-2014 | 03:26 PM
Are you running a 24x? I'm still running the opti so I think 7100 is going to be my limit.
Old 04-22-2014 | 06:06 PM
Thanks.. I think I can get some 6.3s on the 100 shot. With a few tweaks and of course a rear. The 10 bolt took it like a champ. Its not makin any noises at all.
Old 04-22-2014 | 06:08 PM
No im still running the opti. Im shifting at 6900 right now and its still pullin hard. I got to get it on the dyno and see where peak is.
Old 04-23-2014 | 08:32 AM
Mine is all back together. I have had it at my friends shop since the 10th of this month. Just waiting for him to get it in and help me figure out why it won't start. I reverted back to a completely stock style ignition system from the LTCC setup I was running to try and narrow things down. I kind of gave him a blank check to just fix whatever is stopping the vehicle from starting and call me when it's done. I put a new Delphi opti, new opti harness, new plugs and wires on it. The coil and icm are old but I had the same problems when they weren't even on the car and I've tried 2 brand new optis (borrowed one from a friend). So it's got to be either a short somewhere, a bad ground, or my computer I'm thinking.
Old 04-23-2014 | 11:24 AM
onequiklx's Avatar
nice run. I seen u make that pass. I plan on having my ls1 swapped mustang out here soon i hope.
Old 04-23-2014 | 12:16 PM
Looks like you'll be running 9's on just a 150 shot. Sweet!
Old 04-23-2014 | 12:18 PM
Mine is all back together. I have had it at my friends shop since the 10th of this month. Just waiting for him to get it in and help me figure out why it won't start. I reverted back to a completely stock style ignition system from the LTCC setup I was running to try and narrow things down. I kind of gave him a blank check to just fix whateveIr is stopping the vehicle from starting and call me when it's done. I put a new Delphi opti, new opti harness, new plugs and wires on it. The coil and icm are old but I had the same problems when they weren't even on the car and I've tried 2 brand new optis (borrowed one from a friend). So it's got to be either a short somewhere, a bad ground, or my computer I'm thinking.
Ignition issues can be a pain in the *** sometimes. There so many things it could be. I wish you the best and hope you get it figured out. I know you gota be eager to run it.
Old 04-23-2014 | 12:19 PM
Thanks. Hope to see it out soon. Swing by and bs with me next.
Old 04-23-2014 | 12:20 PM
I be really happy if so. If not im goin pill it to it does. Lol
Old 04-23-2014 | 01:28 PM
onequiklx's Avatar
will do for sure. I plan on taking my bike in a week or two and running it. I have a stretched Gsxr 1000 on spray. So far best its been at Brainerd is 5.54@130. Trying to get it in the 40's. Have been a 5.43 @ Crossville though, but I live 20 mins from Brainerd and its my home track
Old 04-23-2014 | 01:43 PM
Damn 5.4s is gettin it. Ive always wanted to go to Crossville. Heard its real good track. My favorite is steele so far. I live about 25 min from brainard and paradise.
Old 04-23-2014 | 11:50 PM
onequiklx's Avatar
Crossville is a great track. Hooks great for sure. You should try it out sometime. I like steele too. But bike is all stock bottom end on a 50 shot so 8th mile is more forgiving. I went to steele last oct and ran a 8.58 @ 162 though.
Old 05-03-2014 | 06:50 PM
carolinaSS's Avatar
Awesome when guys run mid 6's with the stock 10 bolt
Quick Reply: new pb on 100 shot
