First time at track with 02 camaro, kind of impressed
#101
this was at 131. Only got 6 passes in. People kept braking or some one would leak something. The track staff was working. Had to constantly redrag and clean off the truck. Thank you to them.
Nice job Hardtop Brian. Both of us in the 10s this weekend. Great job on motor! My best on motor pass was 11.3x @ 117-118. If I could get my motor passes down to 11.1x or lower i would be jumping up and down.
Winter plans:
intake, throttle body
tube front end from rock solid
tube k member and control arms in the front
coilovers
mini tub rear
narrow rear end
cage
kirkey
weight reduction
get the converter tightened up
the plan is to eventually turbo as that’s how I did all my imports, with this being my first domestic I had to try some nitrous. I’ll try and get a 408 short block going and once the stock ls1 block goes swap to turbo
Winter plans:
coilovers
mini tub rear
narrow rear end
cage
kirkey
weight reduction
#104
Well we got the first snow fall in michigan today. Started on the tear down, got the trans pretty much ready to come out. Radiator was drained and removed. After assessing the car, i think my best option to pick up a rust free clean body car from the south, my cousin lives in TN and paints cars for a living, he is going to help me find one and I will go down and pick it up and swap all my parts over. There is just to much rust damage on the car, wheels are rusting, floor has rust holes, front engine bay has rust, so I am going to find a chassis and swap all my components into it and start with a clean body.
Picked up some side work on a lincoln, michigan pot holes and winters taking a toll on a 2014 mkz with 65000 miles on.
Best 10 second pass from the other day, on 100 shot.
![First time at track with 02 camaro, kind of impressed-smojcnc.jpg](https://ls1tech.com/forums/attachments/drag-racing-results/715968d1683232554t-first-time-track-02-camaro-kind-impressed-smojcnc.jpg)
Lincoln old vs new shock
![First time at track with 02 camaro, kind of impressed-sqz0isw.jpg](https://ls1tech.com/forums/attachments/drag-racing-results/715969d1683232554t-first-time-track-02-camaro-kind-impressed-sqz0isw.jpg)
start of engine bay tear down
![First time at track with 02 camaro, kind of impressed-wxrmtio.jpg](https://ls1tech.com/forums/attachments/drag-racing-results/715970d1683232554t-first-time-track-02-camaro-kind-impressed-wxrmtio.jpg)
