Question about M6 vs. auto ET times
#41
lol yours isn't the only one that changed Even if the auto dropped 1.5 seconds off your time you would still be slower then my car on gate despite me having a horrible manual trans!
If anything I hoped you would swap out that little turbo. I know how that little turbo performs and it just doesn't make enough jams to hang. Once you get the rear sorted out and get a bigger turbo (or add another one) I can see the car going a good bit faster.
#42
Once I get the rear, the plan is to see just how far this small turbo will take me, then step up to a big boy turbo. But as it sits, if I can get it down the track without it breaking.... I'm sure it will run faster than most believe it will with this Chinese turbo. What are you running now?
#43
I'm sure it will go faster I just don't think that little turbo has much left in it. I leaned on a few of those chingchangs pretty hard, even the Precision that size didn't really impress me. You can tell a big difference when you go to a larger turbine and let the engine breath, even the T6 S480 is easily maxed out on a 5.3L. So I decided to change everything up and put twins on there and really let it flow.
#45
#46
To keep the thread relevant take a look at a heavier then full weight manual sedan that runs bottom 9's and we turned it to 34psi and almost 1100hp:
https://ls1tech.com/forums/cadillac-cts-v-2004-2007-gen-i/1879942-hit-dyno-science-1088whp-1051wtq.html
#47
I remember reading your V was running a stock or close to stock T56?
Do you have any comparisons between auto vs stick shift?
All I want is a 9.99 time slip while shifting gears and cruising the freeway without getting passed by mini vans
#49
Disadvantages are it makes a clunk under normal shifting and you have to actually be able to drive a stick......not just putz it through gears. That goes for both ways that gear box moves so rev match down shifts are a must.
#51
No it's not a pita . But you have to be able to drive a stick. Most can't but think they can because they set in the car and can make it move.
No real difficulty on up shifts but you have to shift it like you want it in the next gear. No limp dickin it.
#52
Ya dog boxes are pretty common on high power imports and you certainly have to shift like a man. But overall I thought it was overkill for this build as you can easily have an 8-9 second manual without that option on our transmissions. The import gears are usually weaker so it's a solid upgrade.
#53
From what i have noticed t56 sycros don't really like being shifted over 7k rpm.....especially the fcar ones. Most the clutches are **** for that rpm to and even a little drag will make a sycro'd trans notchy. When after fixing the problem i addressed both issues in my car.
Maybe the upgraded syncros are better at high rpm.....but how much higher? Idk because I've only used stock t56 and my fp'd one.
#54
I believe my clutch wasn't fully disengaging when I had my faceplated t56. Driving around town was always a pain in the ***. I had to double clutch and time each shift just right. If not it was a horrid experience. It was stupid fun on WOT shifts though.
#56
I have watched your videos and mine wasn't anything like that lol. I am willing to bet it was hydraulic issues. I sold mine before I hurt it and went to the dark side
#57
The clutch probably made made a difference too. I went from a clapped out and really heavy Monster twin to a lightweight Tilton triple. The whole clutch and flywheel now weighs less then the monster flywheel. I coupled that with a Tilton slave and a MGW shifter and have zero complaints.
Even with the lightweight clutch you have to rev match or the disks will yell at you. Sintered iron makes quite the noise when you try to slip it.
#59
I don't know what RSG does to the synchros but my trans shifts like butter now. It was really notchy before sending it in which got annoying quick. Now it shifts fast and clean at 7500RPM and downshifts just as quick. George at RSG said they will shift clean to 8000+ and I believe it.
I run a tilton 5.5 triple with a qtr master tri lite release bearing. I love my tilton. We set up in a friends 5gen up with a tilton and used the 6000 tilton release bearing.
#60
Mines pretty easy to drive and I'm very used to it after 40k miles on it.
https://youtu.be/3u6z5shwAo4
The idea of wide open, no clutch shifts sounds awesome.
