stock 5.3, factory cam on nitrous at the track, very happy
Hey guys,
had the truck out last weekend and it was awesome!
its an 85 s10, 90/10 up front, 50/50s in the rear, caltrack bars,
28x11.5 slicks, 4:10 gears, Ford 8.8 diff out of an explorer cut down on one side, a th350 with trans brake, a 2800-3200 stall converter (stalls at 2500 while on the trans brake) with anti ballooning plates and it weighs roughly 3150 with me in it.
this is a bone stock 5.3 WITH factory camshaft, tuned with hp tuners, cold air, headers and flowing thru mufflers.
my truck went 8.5 in the 1/8 mile on motor
it went 7.160 and 91.x mph on a 150ish shot (64 jet) thru a nx shark nozzle in the intake pipe.
and yesterday my best et was 6.75 and best mph was 98.3 and my best 60 ft was 1.43 all on a 250ish shot! (85 nitrous jet) thru the same nx shark nozzle.
I pulled 12 degrees off of my 26 NA timing with my lnc 2000 box and pulled an additional 4 degrees from 2800-3200 rpm in the computer with hp tuners to soften the hit a bit and was running vp110 for motor and nitrous with a b8efs spark plugs.
I had my window switch set to turn the nitrous on at 2800 and left the line around 2500 rpm with the trans brake and against the converter.
