First day out, all kind of issues.
Old 03-10-2018, 11:16 PM
Basco's Avatar
Default First day out, all kind of issues.
I tried my car out at the track today but I had bad wheel hop and some electrical issues. When I launched, the car lost power momentarily and then again when shitimg into second. You can see the tail lights went out when leaving and you can hear the car shut down in second gear. Drives fine under normal conditions and it even does fine when under load on the street. It did it when it hooked. I have some checking to do but I am open to suggestions
With that horrible launch amd shutting down, it ran a 12.7@115 with a horrible 2.08 60ft. I have some homework to do.
Old 03-11-2018, 03:57 AM
zzracer's Avatar
Make sure your battery is not moving around and the terminals grounding on something.
Old 03-11-2018, 07:30 AM
ragtopz28's Avatar
If your battery is in the stock location...I can tell you with 99% certainty that it is rocking back and grounding out. It happened to me, ONCE, then I made a top mounted hold down for it.
Old 03-11-2018, 09:12 AM
Basco's Avatar
Thanks guys, I will check that first.
Old 03-11-2018, 01:49 PM
Basco's Avatar
100% correct, thanks much!
Old 03-11-2018, 03:09 PM
ragtopz28's Avatar
This will do it.
Attached Thumbnails First day out, all kind of issues.-img_20180311_160746004.jpg
Old 03-11-2018, 03:18 PM
Basco's Avatar
This will do it.
Yes sir, simple solution. I will get to it this week while I wait for a new set of control arms. I have a little bushing squeak and the rear end has some play. I have boxed control arms that came on the car and I am suspecting the bushings might be shot.
Old 03-11-2018, 04:19 PM
ragtopz28's Avatar
Get some LCA relocation brackets.
Old 03-11-2018, 05:06 PM
codyvette's Avatar
It's ironic you posted this today. I went to Royal Purple Raceway last night with my six speed car and on the second pass, the car seemed to pretty much die and all of the lights on the dash came on. I didn't think about it but that damn well may be what that was. 4k RPM clutch dumps can move a few things around I guess. I have known my battery tray was in shitty shape for a long time but never really raced it at the track.
Old 03-11-2018, 05:17 PM
codyvette's Avatar
The time slip you posted looks almost identical to mine as well. The last pass I made there was no hiccup and the car went .4 faster.
Old 03-11-2018, 05:41 PM
ragtopz28's Avatar
Haha, when mine did it, sparks flew everywhere, and people thought I had blew tranny, motor, etc. I've got a vid I will have to find...
Old 03-12-2018, 11:59 AM
Basco's Avatar
When i shook my battery to check if it was secured, it made contact and there were sparks all over. Scared the **** out of me!
Old 03-12-2018, 09:42 PM
Basco's Avatar
I think i found the wheel hop problem. All the control arm bushings are shot!
Old 03-13-2018, 09:56 PM
zzracer's Avatar
Your welcome! You'll get it all the bugs worked out and dialed in. Just takes time.
Old 03-14-2018, 07:50 AM
codyvette's Avatar
Those poly bushings must have been beat on pretty good to have slop like that.
Old 03-14-2018, 10:41 AM
ragtopz28's Avatar
Found it...
Old 03-14-2018, 11:46 AM
Basco's Avatar
Pretty common it seems. Wish I knew before but we live and learn!
Old 03-14-2018, 12:12 PM
Basco's Avatar
That's what I was thinking. The whole rear end had play.
Old 03-14-2018, 10:54 PM
codyvette's Avatar
Checked mine when I got home today.
Old 03-15-2018, 05:31 PM
Basco's Avatar
Glad you found it too, pretty annoying and a track trip wasted!
