**New Personal Best in the 1/8**
Old Oct 27, 2022 | 03:25 PM
madmike9396's Avatar
Default **New Personal Best in the 1/8**
Went to a no prep event last night and ran a new Personal best in the 1/8. Previous best was 7.04 @ 96 mph with a 1.46 60' ft
The only changes were adding a chrs1313 prostock ram air, 42lb injectors, maf delete/re-tune & Viking Warrior Coil-overs to the front.
Resulted in the following
60' - 1.435
330 - 4.397
1/8 - 6.92
mph - 98.36
Full weight- 3600 +
i believe with less fuel in the tank (on full last night) and some track prep i might be able to crack off a 6.8x
either way i am excited to have joined the 6 second club in the 1/8 with my full weight car. NA
Old Oct 27, 2022 | 03:30 PM
zzracer's Avatar
Congratulations Mike! I know there is 6.80s in your future. Humidity was high last night and no prep at all was hurting you for sure!
Old Oct 27, 2022 | 05:36 PM
Tuskyz28's Avatar
Badass!! Shoving air into a engine really helps it ....
Old Oct 28, 2022 | 05:22 PM
Thanks ! slowly chipping away at it. trying to get to your level one day
Old Oct 28, 2022 | 05:23 PM
Help some on this turd for sure
Old Oct 30, 2022 | 06:43 AM
Shadow02SS's Avatar
Congrats on the pass, that is 10.88-10.92 in the 1/4, very close to my wifes t/a in ET. What did you run for air pressure and you flashing the converter? That is something I still want my wife to try with the PT converter we have.
Old Oct 31, 2022 | 06:00 AM
Thank you! I'm running Mickey Thompson Et street R. 255/60-15 I had mine at 18 psi. that was flashing the converter.
I believe i could tighten my rebound up some and get more out of the 60'. I've got to get an aftermarket driveshaft before i go back.
Old Oct 31, 2022 | 06:10 AM
Shadow02SS's Avatar
Yeah my wife has been loading her PT4000 at 2,000ish rpm, and we are running 19lbs of air, next time we go for TNT going to try to leave at 1000-1200rpm and see if it likes that better, but she index races hers alot so 2000rpm seems to give her the best reaction time.
Old Oct 31, 2022 | 06:50 AM
you could probably play with that front suspension some and net some better 60s. i seen that wheelie in your latest post. Freaking awesome !
Old Oct 31, 2022 | 05:09 PM
Shadow02SS's Avatar
Yeah, on our local track it went 6.77@99mph with a 1.42 60FT with the 10 ways set at 4 clicks from soft, Da at that event she won was -100 FT, The SCT darlington event she won the women's class running 6.82-86 da was 800-1500 that weekend shocks were 2-3 slicks from soft. Might try 5 clicks next spring when we go out, Im trying to talk her into a intake.
Old Oct 31, 2022 | 06:22 PM
I had my Vikings set all way tight on the comp and I went all way negative then up 8 clicks on the rebound. A friend standing at the line said it jerked the wheels up pretty quick. wish I would of gotten a video.
Old Nov 4, 2022 | 09:00 PM
98LS1auto's Avatar
That was my fault. My bladder couldn't hold out any longer. I"ll get you one next time.
Old Nov 4, 2022 | 09:02 PM
98LS1auto's Avatar
That red car sure is nice.
Old Nov 7, 2022 | 04:17 AM
Look Familiar huh ?
Old Nov 11, 2022 | 01:00 AM
PARMY's Avatar
Congrats on the new pb Mike, solid run! That is a stellar 60ft
Old Nov 11, 2022 | 04:07 AM
Thank you !
