New PB 10.22@139.75mph Monaro
Well finally cracked a solid 10 in my street driven Monaro here in Australia , this makes it the fastest and quickest LS1 presently in the country.
You can checkout the buildup from a 12sec streeter to the 10 sec time on my website here Project Monaro , look under Project Monaro
On a Dyno Dynamics dyno it makes 607 rw hp through the A4 , that is a full load cell dyno , on a dynojet like is used in the US it makes 677 hp at the treads
Finally got a link to the video of the run - check here http://www.vyssute.com/photo/albums/...0001/10.22.MPG
Sweet!
What engine and power adder setup?
Andra decided it was time for us to go home after a couple of passes as it now needs a cage,chute and full harness but unfortunately it is illegal to have a street car in WA with a cage so it wont be back at the track again.
![](http://chipmaster.com.au/webpics/monarovy.gif)
Time slip and Dyno graph here http://chipmaster.com.au/Project%20Monaro8.htm
Video of the run is here
10.22 drag pass
It is a SQP 383 , with a 226 cam , 4L60E that has had some serious work done , std factory stall, 3.7 gears with factory LSD ,whipple starr charger running @ 10lb , full build up can be seen at www.chipmaster.com.au , look under project monaro
60' was a little slow since I am running a std stall and street gears - would have loved to have tried it with some more diff gear and a stall.
Thing is absolutely awesome on the street though.
I will take some pics of the engine and post em up
