All 6 Speed Folks Get In Here and Post!!
K, well I was doing some meandering through our timeslip database and it really didn't answer what I was wondering. Basically I just want to see how us M6 folks are doing these days
Pretty simple what I want to gather here.
Post up:
1-Best slip so far..60 foot, 1/8th, 1/4 and MPH's.
2-Your engine Displacement and if you are solid roller or not
3- Power adder or no??
4- Raceweight.
5- Rear gear and tire you are running. I think this could be helpful for alot of the M6 folks who are wondering what gear and tire they should try with their mods...
6- AS REQUESTED, GOOD IDEA. Also toss up your clutch/flywheel/hydraulics info
Post up:
4- Raceweight.
Ok, I will start.
60': 1.546
1/8: 7.192
1/8 MPH: 96.28
1/4: 11.243
MPH: 121.30
edit, new best tonite:
60: 1.513
1/8: 7.079
1/8 MPH: 97.48
1/4: 11.093
1/4 MPH: 122.41
*have had 1.52 sixty foots before, along with 123 MPH.
2- Motor is Speed Inc 347", 10.8:1 compression, hydraulic cam.
3- No nitrous used on the above mentioned pass, N/A.
4- Raceweight is at or a bit above 3400 lbs.
5- I run 4.71 gear and a spool with 28X10.5X15 Et Drags.
6- Spec Stage 3I with Spec Billet steel flywheel. Stock 02 hydraulics with drill mod done.
60': 1.546
1/8: 7.192
1/8 MPH: 96.28
1/4: 11.243
MPH: 121.30
60: 1.513
1/8: 7.079
1/8 MPH: 97.48
1/4: 11.093
1/4 MPH: 122.41
Here's mine:
60': 1.429
1/8: 6.708
1/8 MPH: 101.35
1/4: 10.538
MPH: 128.62
2- Speed Inc Forged 348" w/G5x3 and AS Stg II 5.3's.
3- NX 150 shot, nitrous cut off at 1000' mark (need taller tires).
4- 3480 lbs.
5- 4.10 gear w/26X11.5X15 Et Streets.
Hoping for at least 10.3's with 28" ET Drags
60': 1.429
1/8: 6.708
1/8 MPH: 101.35
1/4: 10.538
MPH: 128.62
4- 3480 lbs.
Here is mine
60ft: 1.83
1/8: 7.94
1/8 mph: 89.39
1/4: 12.32
1/4 mph: 112.29
2: Stock Internal 346. Only Bolt ons(mods in sig 1999 Camaro SS)
3:No power adders
4: 3450 raceweight
5: I run stock 3.42s in the 10bolt with 275/40/17 Nitto 555R, 9" on the way with 4.11s
Dan
60ft: 1.83
1/8: 7.94
1/8 mph: 89.39
1/4: 12.32
1/4 mph: 112.29
3:No power adders
4: 3450 raceweight
Dan
When my car was a M6 with stock suspension my best goes as follows
60ft 1.58
1/4 12.10@114
raceweight was 3750lb
mods were 4.1's, 224 cam, mac's and the usual bolt on's on a 26x11.5x16 E.T street.
60ft 1.58
1/4 12.10@114
Originally Posted by SilverGhost
Post up:
60'- 1.44 1/8-6.38@114 1/4-9.93@143
Hyd 422ci
200 shot through a TNT collar
4- Raceweight.
3500 pounds
Hyd 422ci
4- Raceweight.
3500 pounds
best 60ft 1.68
1/8 et 7.44
1/8 mph 95.5
1/4 et 11.60
1/4 mph 119.5
NA run, got NX MAF kit now no times yet
stock 02 Short block 346
TEA 5.3 11:1 CR FMS 230 232 cam
390 gear
I would guess 3650 raceweight(02 WS6 1/4 tank no spare 18in z06's up front 26 10.5 16 et streets on firebird wheels sway bar on car so no weight mods im sure somebody knows what my car should weight by desciption there)
ill have new times soon got a set of Bogarts in here 15x4 and 15x10 with 26 10 15 et drags gonna pull the sway bar and seats and see where that gets me NA then spray the bitch
1/8 et 7.44
1/8 mph 95.5
1/4 et 11.60
1/4 mph 119.5
390 gear
I can shift faster than you.
60' - 1.439
1/8 - 6.588
mph - 104.23
1/4 - 10.326
mph - 131.70
Best 60' - 1.409
Forged 348ci shortblock, Thunder Racing ported 5.3l heads, Cam Motion 246/250 .632/.628 110lsa hydraulic roller
Naturally Aspirated
Moser 12-bolt/4.56s (spool), M/T 28x10.5x15 ET Drags, suspension setup by Madman
3238 lb. raceweight
Video of 10.32 pass: http://members.***.net/kcr19/jason1032.wmv
1/8 - 6.588
mph - 104.23
1/4 - 10.326
mph - 131.70
Best 60' - 1.409
Naturally Aspirated
3238 lb. raceweight
Best 60-1.48
Best 1/8- 7.0x@96.x
Best 1/4- 11.1@122 around 3475lbs for all times above
Best mph 123 on a mid 1.5 60 after more weight reductions (around 3375lbs.) bad night crappy traction, should have been my first 10.9x DA around 1600-1800
Suspension: brm lca, relocations,torque arm, phr, sfc, stock shocks,sway and springs
Rear: Moser12bolt, 4.56's, spool now but runs were on a posi,
Tires: mt 28x10 et drags
stock trans
spec 4 clutch
100% stock bottom end and stock heads, trex cam
Best 1/8- 7.0x@96.x
stock trans
spec 4 clutch
Best N\A on new setup at 1789 DA:
60' 1.425
1/8 6.667@102.77
1/4 10.42@131.97
Forged 348 shortblock,LS6 heads,FAST 90mm w\soild roller
Moser 12-bolt(spool) w\4.88 gears and 28x10.5 ET Drags,RAM clutch,BMR drag bar,Random Tech TQ arm w\custom rearend bracket,BMR LCA's,HAL shocks and Eibach springs-STOCK TYPE T56! -3290lbs
Best N2O pass on old setup:
Forged 348 w\250HP
60' 1.54
1/8 6.37@110.5
1/4 9.88@144.24
Best N20 60' 1.37
Same suspension w\4.30 gears-3500lbs
60' 1.425
1/8 6.667@102.77
1/4 10.42@131.97
Forged 348 w\250HP
60' 1.54
1/8 6.37@110.5
1/4 9.88@144.24
Best N20 60' 1.37
LS1TECH Sponsor
60' Best is 1.58 but more in the 1.6 range
1/8 don't remember
1/4 11.61
Stock Short Block with HC package
Tires are 26x11.5x15
Moser 12 bolt with 4.10 gear
race weight 3725 It's a pig and we're working on that.
1/8 don't remember
1/4 11.61
Here's mine
60': 1.452
1/8: 6.8??
1/8 MPH: 101.??
1/4: 10.550
MPH: 131.??
2- Stock Bottom end, Stock Heads, Futral FM-8 cam (225/233 590/590 114lsa)
3- Hybrid 250 wet shot (very lean)
4- 3470 lbs.
5- 4.10 gear(spool) w/28x11x15 Goodyear Eagle slicks D-3 compound.
60': 1.452
1/8: 6.8??
1/8 MPH: 101.??
1/4: 10.550
MPH: 131.??
4- 3470 lbs.
60': 1.535
1/8: 7.010
1/8 MPH: 98.61
1/4: 10.961
MPH: 125.04
have had a best of 1.47 60' last year at NPR...
2- Motor is a Fireball-special 346 Stock pistons, rod and crank with new rings, bearings and rod bolts... Assembled by yours truly
3- N/A.
4- Raceweight is ~3450.
5- I run 4.30 and 26x10x15 Et Drags. I just switched to a 28x9x15 ET Drag though...
1/8: 7.010
1/8 MPH: 98.61
1/4: 10.961
MPH: 125.04
3- N/A.
7 Second Club
Location: Grove City Ohio/Port Washington L.I sometimes
2003 Z06
Mods
4.10 gear
Zip-tie mod
CCW drag pack wheels with 26/11.5 ET Street
Hurst shifter
Raceweight was 3190 according to scale at US41
Best run ever was at N vs S in June(time in sig);think DA was +1500-1600.
The car runs 11.81-11.84 most of the time under decent conditions
Mods
4.10 gear
Zip-tie mod
Hurst shifter
Best pass so far (second trip to track)
1.71 60ft
7.35 @ 95.3mph
11.39 @ 122.8mph
The first trip to the track I ran a 1.63 60ft
Stock 27k mile shortblock with PRC 5.3 heads and PRC 225 cam.
12 bolt with 4.10's and 26x10.50 et streets. Stock suspension with no front sway bar. Raceweight was in the 3480-3500 range.
1.71 60ft
7.35 @ 95.3mph
11.39 @ 122.8mph
60'- 1.513
330- 4.513
1/8- 7.00
98.50
1000-9.150
1/4 10.940
125.7
95 TA with a 00 LS1 stock bottomend . Our ported stg. 1 LS1 heads, 234/242 hyd cam, FAST 90mm intake N/A
3350 race weight 950 DA 4.57s 9inch, stock struts/springs
330- 4.513
1/8- 7.00
98.50
1000-9.150
1/4 10.940
125.7
Post up:
Best 1/8th: 7.12 (powershifting)
Best 1/8th mph: 98.8 (Powershifting)
Best 1/4: 11.10 (granny shifting)
Best 1/4mph: 125.05 (granny shifting)
385ci stroker, hydraulic cam
NO
4- Raceweight.
3620
4.11 gear and 28x9 inch slick (27.3 OD)
I am looking to run 10.90s next time out. Still running cats
NO
4- Raceweight.
3620
