G5X3 at the track
With that cam, your trap speeds should be higher than that. How did your car dyno?
P.S.- I have lousy 60' times in the 2.0s on street tires. My drag radials have been ordered.
When the car was tuned what did it dyno?
Edit- guess i missed that. It is definitely in the tune. Check the o2's and get the car retuned.
There's no trick to installing a cam and if it wasn't degreed properly it would have shown up in the dyno numbers. 385 rwhp from an A4 car with presumably stock heads is damn impressive so I don't think the install is the problem.
You're either losing power somehow (KR or something else) or your dyno numbers were somehow skewed. I'd get the car redynoed (somewhere else than the last time) and see what your numbers look like. Also, have them check for knock retard at WOT.
TexMax: Do you have your unlocked numbers?
I see that you drive an M6 car, so take a look at this list and educate yourself.
http://ts.cranesystems.com/2002Corve...5Auto_ver2.htm
