9.6 @146 turbo 6-speed LT1
Run was made through a modified SLP two on the left exhaust (3.5in inlet and over the axle pipe).
22lbs of boost
60ft was 1.48, clutch started to slip a bit in 4th
Raceweight was 3,780
I opened the exhaust and turned up the boost for another run, and I completely destroyed the clutch. Oh well.
www.ls1speed.com/movies/jim_968.WMV
22lbs of boost
That car is bad ***. In the video you hear it "slide" into 4th gear. You might have gone a high 9.50 with a couple more mph if it didn't slip in high gear.
That car must be a blast on the highway.
