Track Results (FINALLY) AFR 205 Project Car
Hello....
First I would like to say I'm getting a little tired of seeing my car on the back of a FLATBED !! (twice within the last couple of months....)
Anyway....on to the better news.
Had the car at the Bakersfield private event today and finally had the chance to run it without transmission problems and other assorted BS of late that kept me from getting these results sooner.
The D/A today was not as great as everyone was hoping for....actually, it was a beautiful day for hanging at the track, but too warm for putting down serious power numbers. My weather station had the day between 1200 and 1600 ft above sea level (confirmed by another weather station as well)....unfortunately, most of us had hoped to see it as low as 300-600 and some earlier reports suggested that it might even be negative (no such luck), but I'm not complaining because I usually run at LACR and the D/A there is usually 4000-5500 feet.
My first two runs I choose to keep the air pressure in the ET Streets around 20 lbs. to try and avoid breaking parts and get a feel of how the track was hooking (I should have kept that philosophy!) and with both of those runs spinning out of the hole (and on my 1-2 shift), the car ran an 11.42 the first run and an 11.50 the second, with 1.80 and 1.81 sixty foot times. Not all that impressive until you look at the MPH which is a much better indicator of "power" (as most of the sharper drag guys know)....The car ran 123.98 and backed it up with a 123.96 the second run!!
I was extremely pleased with those results as my car is quite heavy for a Vette....With me in it, the car weighed exactly 3440 lbs. today. It certainly is no stripped down Z06 with skinnies etc, that would come in 200 lbs less with an average weight driver. In fact, I ran my standard front wheel package which is a fairly heavy 285/35/18 Nitto.
I was confident with a better launch I could run LOOOW 11's at maybe 125+ and directly after the track was re-prepped I dropped my tire pressue to 15 lbs and side stepped my new Exedy dual at around 5800 RPMS.....The end result was a big BANG....and the car went NOWHERE. Enter AAA an hour or so later and the rest is history.
As stated in an earlier thread, MANY Corvettes spit some driveline parts today....I wish these cars could be made more "bulletproof". I will be taking her apart AGAIN probably tomorrow to try and locate the cause...stay tuned for the next round of "carnage" !!
Regards to all,
Tony Mamo
Regards to all,
Tony Mamo
What RPM were you shifting at? What gears in the diff?
My stock FRC with a half tank of gas, 21lb trailer hitch and Z06 mufflers is 3100lbs even. Can't wait to get it down to 3000ish with all the bolt-ons, light battery, etc. and see what it traps with some of your heads.
Weren't there other AFR cars running?
Thanks.
Thanks.
12 Second Truck Club
It was a nice day at the track, a little warm, but nice. I declare today "National Break Your Corvette Day," as there were more broken vette's than anything out there today. It was sad. Good numbers though, Tony! Hope to see you AFR guys out there more often, tell Guy we're gonna have to have a grudge match next time out. That is one fast 4x4/crew cab/long bed/camper shelled Duramax he's got there!
More Info...
Guys...
Dont forget that this is the AFR "street" package I spoke about in great length a few months ago....224/228 cam, FAST 90, etc....very stealthy, perfect driving manners, and big power. This is about as close to "eating your cake and having it to" as it gets. Shortly, I will be developing the next package to be featured with the same stock shortblock, in the same vehicle, that will feature the small shamber 225's and the next custom ground cam in AFR's LS lineup. Although I HOPE to see an additional 30 RWHP putting me solidly over 500 RWHP (with no tricks or BS and including the loss from 3.90 gears), I know that my docile "stealthy" driver part of the package will be compromised somewhat. With that in mind we plan on doing lots of dyno work and R&D to try and keep it acceptable enough for a more aggresive "daily driver" and although a bigger cam would obviously make more power, we are going to still hang our hat slightly on the conservative side. The better the cylinder head is, the less of a need to go "huge" on cam timing to put up big numbers....we will leave that to some of the tuners and individuals who are less concerned with driving manners and more concerned with maximum power output. To be honest with you guys, I feel more of you on this forum (LS1 Tech) would probably opt for the package currrently in the works, but trust me when I tell you that ALOT of people would sacrifice that extra 30 or so to keep their driving manners similar to stock.
Anyway...sorry to get de-railed there for a minute.
Grant, I was shifting right at 7050 or so (7000 RPM Shift light plus reaction time) and as I mentioned earlier with 3.90's out the back.
As far as the other AFR cars went, the few that I knew about also broke (no joke) and then I got hung up with the whole "AAA Flatbed" thing and unfortunately didnt see some of the other cars go. Im sure they will chime in when they get a chance. I would have liked to have been a spectator for awhile....It was really comfortable out there today.
Thanks,
Tony M.
Thanks,
Tony M.
Originally Posted by Tony Mamo @ AFR
Guys...To be honest with you guys, I feel more of you on this forum (LS1 Tech) would probably opt for the package currrently in the works, but trust me when I tell you that ALOT of people would sacrifice that extra 30 or so to keep their driving manners similar to stock.
Thanks,
Tony M.
Thanks,
Tony M.
Video of 11.50 Run...
Thanks to "Pat and Kat" McSwain I have a link to my second (and final) run of the day. Im guessing there was 21-22 lbs of air on this run because I basically just hot-lapped it around the track and I'm sure the tires were still hot from the first run I made which seemed to hook (and ET) a little bit better.
Thanks for the video guys....sorry to see you "break" again as well.
http://fuzzydiceracing.com/k/Tony1250.wmv
Tony M.
Tony M.
Originally Posted by gollum
Tony,
With the same engine combo installed in a equal weight M6 F body, could you run quicker times? Put another way, does the F body make a better dragstrip car?
Also, I'm thinking a well set-up F-Body could transfer weight more efficiently than a Corvette, which is really better suited at a road race event than a drag event. I think what is becoming painfully obvious for me is that until the aftermarket builds some bulletproof parts for the C5, I might just have to "give up on the ET" for awhile, keep the tire pressure up, and get a lot more seat time than wrenching time. Even with a mediocre 1.80 sixty foot, the car was pulling like crazy down the track and I was still having a blast rowing the 6-speed.
Personally, Ive always been more of an "MPH" kind of guy anyway because that's what is showing you how hard the car is pushing you back in the seat on the ride down the 1320....."ET" is primarily an indicator of how well the car works and how good the driver is. Negating the first 60 feet of the track, a car capable of 124 MPH trap speed would be door to door with a "10.70" car that was totally optimized for drag racing. Granted, to have both (a car that exploded out of the hole AND pulled crazy MPH) would be nice, but your not typically going to find that in a dual purpose "compromise" car, especially one set up more for road racing than drag racing.
Joel ("JB's Blown C5) ran a best ET somewhere in the 11.50's I believe, but did so at 132+ MPH (not to mention he DROVE home....LOL) Granted, he's making over 600 RWHP, but I bet his car was a blast to drive down the track and because his car isn't set-up for the ultimate ET (which I'm sure would have ended in another flatbed call), he drove home to tell about it.
Just some thoughts I felt were worth sharing...
Regards,
Tony M.
Corvette rear CV joints are a problem also. When SLP installed their 408ci engine package in their R&D GTO, the engine produced so much torque the rear CV's broke.
Tony's car is making a lot of power with just 346cubic inches.
Hey maybe you could have Guy put 5 people inside his truck instead of 2 next time.... and maybe pull a trailer.. then you might have a race!
