New Cam Only Record! 10.344@ 128.20
Originally Posted by Magnus
Video of a slower 10.34
Broken Torque Arm Carnage inside the car
Thanks for the pics and videos Tim!!!
nice runs by anychace do u have any pic of the inside of the car
LS1TECH Sponsor
No pics of the interior..
I have:
Stock cloth seat.
Shifter.
Dash with gauge cluster and my switch assembly in the middle, tach on the right, 3 pillar gauge pod on right, pillar cover on the pass side, head liner up top, and the cross bar on the bottom of the dash. i also have a 13" drag race steering wheel. 8pt roll bar.
I think I cut the 1.31 by letting off the brake as the RPM's were ramping up.. I engaged the brake at idle, then went WOT and I think I let go of the button as the RPM's were about to come up to the flash point. It just shocked the crap otu of the car and it hit hard..
I honestly shifted into second only a couple of hundered RPM later.. It hit around 5200 then around 5800 I was in second gear.. I freaked out.
I have:
Stock cloth seat.
Shifter.
You forgot to thank me for bringing the much needed fuel of egg mcmuffins at 6:15AM. We had to deal with a retard in the drive-thru who couldn't understand I wanted two, not one. ![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Nice runs - was awesome to take pics of the wheelies.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
#33
Keith is the man!
I think I need more converter and 150 less pounds.
I redlight the 1st race against Keith (-.003) and the car took a hard right @ 600ft,
got back in it and stayed on his door.
Second race left pretty even he jumped out and I couldn't pull an inch.
We had the same 60' but he got to 330' quicker than me.I need a 5500 converter.
My car pulled 1.41-1.42 every run, ran consistant 10.50's@ +550 to +1000DA.
Weighs 2950ish probably.
Congrats again, Keith!
#40
LS1TECH Sponsor
I have the stock gear set. I figured I would have issues keeping the front down so I didn't want to add to the problem.
I'm sourcing a new driveshaft now and think I will just go with a moly driveshaft. I see 1.2's with more powerful setups in the future.. Not sure how a 3.5" aluminum will do.
If I can get a new torque arm this week I may go to the track again sunday and see what I can do.
I'm sure the car has 10.2's in it with a little better air and some more low 1.3 60's..
I need to see if I can make it a little harder for Rodney.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I might throw on a set of heads in a bit to see how close to the 9's it gets.. but I highly doubt it will actually go 9's heads/cam..
