Please post your FM11 & FM13 cam only performance results (track & dyno)
Please don't tell me to use the search button, I have been doing searches on these cams but just trying to get a single compilation of people's results and also trying to get the most up-to date info as well. Hopefully I get a few responses...
I have the F13 with 112lsa on my 2000 WS6 M6. I made 362HP 355TQ without the LS6 intake,portedTB and a shity exhaust (FLOWMASTER). I am still running the stock injector's (26LBS) and when I put the intake and TB and my GMMG W/ some 30LBS. I think I should be 390-400. I ran at the track with no traction 12.9 112 MPH. It was hot as hell to so that didn't help much and I know with some good tire's I will hit 12.5 no problem or even better then that.
Originally Posted by GuitsBoy
I dont have any dyno numbers or track times, but i can give you a ride sometime... Just gotta finish tuning it
Originally Posted by KB99WS6
is that also with stock headers and stock catted Y-pipe? Yeah b/c I was expecting at least 400rwhp if I get the F13
A friend of mine did the F13 cam. With long tubes, 2.5" true duals, ls6 intake, and a 3500 tci stall with 3.23 gears went 12.3 @109 with 2 loose distributor cables in the heat. DA I believe was around 1900. Should go 12.1 with some better weather and the higher shift points. Car was shifting at 6400 rpm. I don't remember the dyno numbers. Stock weight 01 camaro with mt drag radials and 275 front stockers.
How timed the cam ? or did you just lay it in there ?
It seems to be a unanimous decision to go for the FM 13 cam when upgrading however nobody has dyno sheets ??
Come on lads, lets see some graphs I would love to see what to expect as i have pretty much decided this is the cam for me but would like that final push.
I however, am so technophobic that i wouldn't have the first clue as to be able to put my dyno sheet on the comp; but i know a man who can so will do when the results are in.
Keeping it real from across the pond
Rob
Rob
F13 112+4 here, this cam is very impressive it consistently put down good dyno# and track times.
It has good street drivability, track results and sounds good.
Just call Allan @ FMS and he will help you pick the best cam for your set-up.
My track times are at a very poorly prep track with DOT tires.
11.53 @ 120.62 1.67 sixty’s DA 2130, race weight 34?? lbs
On my old 99z A4(now in car heaven) i made 388rwhp locked(tuned by Allan@FMS) w/ the F11, vig3200, mac mids, x-pipe w/ turndowns/bullets, ls6 intake, asp pulley, free mods, ported TB, etc etc through stock rear w/ 3.42s. Some time after the dyno tune, i developed a few probs and never got a good pass outta it though(12.40@109.8mph) due to alot of KR everytime the car shifted & the shift points were off. It kept shifting at 6100 instead of 6600 like it was supposed to.
think i had a bad knock sensor or the exhaust was hitting the underside of the car at WOT causing false knock, either way the timing was being pulled back and never got a chance to get it fixed before i wrecked it unfortunately.
i have the graph but scanner is broke so cant get it scanned in.
2000 M6
F13 cam only. Kook's longtubes, all bolt ons, homemade dynomouth through 4.10 gears.
395 Hp 383 Tq. Not the greatest, but I'm not worried. Missed my goal by 5 Hp
Jesse
