1st time at the track in the snake with tires
Old 04-24-2006, 02:26 PM
Vcious04's Avatar
Default 1st time at the track in the snake with tires
Finally got a chance to run the snake at the local 8th. Warm humid evening, appr 83 deg. No track prep.
Best out of 3 runs... running 275/50r15 MT drag radials on telestars.
r/t .219 (asleep)
60' 1.800
330' 4.928
mph 72.92
1/8 7.524
mph 95.44
Slipped to clutch to load the rear about 3.5k rpm. I think with better traction and with my 4.10's installed I might be able to pull a low 7. Happy with the times though.
Old 04-24-2006, 03:20 PM
chrs1313's Avatar
nice times maybe next time they will prep it better for you
Old 04-24-2006, 04:19 PM
Denom's Avatar
Wow, impressive times. Nice 60' btw, but I know the car has the power to do even better. I'm sure you'll love the 4.10 gearing. I know I do
Old 04-25-2006, 09:50 AM
chrs1313's Avatar
yeah right i am not doing 4.10s they are only worth about 1 tenth over 3.23's and the way gas is going you got to be nuts to have 4.10s in an auto, maybe a stick i could see but not an auto...of course if it wasn't my dd i might think differently...plus i am on a stock 10 bolt...this is what my rear would do
thanks for the compliments
Old 04-26-2006, 09:16 AM
Vcious04's Avatar
Thanks. Just trying not to beat the irs to bad on tires. Try to load the driveline then slip the clutch. 4.10's should be easier on the clutch I assume.
With a little more weight reduction I hopefully will run 7.0's.. Would love to run the magical 6's.
Old 04-27-2006, 01:32 AM
Denom's Avatar
I drive a 6 speed, not an auto. With the automatics it's best to just alter the torque converter, as obviously gas prices are soaring.
Exxon is real happy though, they declared an $8.9 Billion Dollar profit this quarter.
Old 05-03-2006, 05:08 PM
RGR Pete's Avatar
1.8 60' is a really good for IRS, good luck
Quick Reply: 1st time at the track in the snake with tires
