WTB: Traction!
Bottom end can hold up pretty well. Just make sure the tune is good up to those RPMs on the hit. You want to be in the high 12s with no more than 27*.
but i think that 6500 is where my rev limiter is set at? i gotta check...where should it be at? Remember, this is more of a street car, so I want it safe, I only go to the track a couple times a year
I know my tune is for 28* right now
So can everyone agree that its my shifting that is due to my times? I mean, it was my first time out, and I'm not used to launching...I more or less just dropped the clutch--let it out very quickly
What should my car do with this setup? (no nitrous, and assuming i get my driving down)
I'm goina keep the front sway bar since it is a street car, just curious though
does it seem like slicks are going to be a "must have" or does these nitto's seem to be doing the job? I was breaking them loose pretty easily
6400-6500 on the bottle
Just because nitrous makes a lot of torque and your not really doing any good spinning it real high on the bottle, plus if you have a stock bottom end the rod bolts are weak and may break if you turn it real high on the bottle. Now I have run mine higher on the 100 shot to keep from having the hit 4th gear at the 1/8th mile track. The result was my trap speed went from 98 to 100.
UMI tunnel brace mounted torque arm here. I love it. Best 60' of a 1.58, spinning (it had sprinkled and the track was a little damp)
Its powdercoated black and its all shinning and pretty. Watch out momma I'm going fast!
