HELP! big cam stock cubes guys
i have recently swapped my c1 222/222 .570/.570 112 for a bullet 242/248 .603/.603 112 and have tuned my air to fuel via wideband to 12.5~13.0 and have slowed down i have a 5200 8" ptc 4.11 w/28" radials
was 1.40 60' 10.70's 122 now best of 1.44 60' 10.75 121 with only and same weather i do still run stock injectors but my afr looks good
please help ive been tuning for 3 weeks and going crazy
getting it on the dyno just to see what its doing would be a good idea. obviously at this point you track dyno says your bigger cam and new tune aint worth ****. get it checked out man, it'll be worth it. whats the car weigh?
Originally Posted by Red01Chevy
3200 lbs if my afr is where it should be would there be any advantage to bigger injectors
peace
What heads are you running and is this on spray? I have a hard time believing a 10.68 @ 123 with a C1 cam. Maybe with one of the bigger cams. Are you 100% positive the previous cam was a C1?
unless mti sent me the wrong cam and stamped it wrong it is a C1 and ive checked the lift with a caliper and its dead on but i have no way to check duration. and i have nothing to hide or lie about 10.68 @123 for one i only bracket race and occasionaly street events and i dont want nething to do with nitrous that is only good to break parts.
Originally Posted by Houston999
change the shift points .... dyno your car and shift about 200-300 rpm after the peak hp
if your on a stock fuel pump and injectors your nuts weather thats the problem or not, i was running an excessive duty cycle cam only.
btw, is this waguespack? your dad drives the old vette and i think your name is scott?
