The "Heavy List"
#102
big dave...
12.27@113.4 for the SS. 3700 lbs+- depending on gas. JH LTs,ORY,cutout,FTRA,4.10s,ls6 intake,street tires.
big dave...11.71@ 117.4 for the 94 Z28. 3700 lbs. H/C, stock bottom end,3200 stall,3.73s,SLP shorties/borla.
#104
Pathological Modifier
Just to bump Ellis:
Board ID - 1/4 ET @ MPH (60ft), Yr & Type of car, Trans, Converter/Clutch, Gear, Heads, Cam, motor, Cubes, Power Adder, amount,
DA, Race Weight, Date
Ryan K - 9.989 @ 128.15 (1.494), 98 Camaro B4c, TH400, ATI MRT Custom, 3.50, AFR 225's, 224/224 Comp Cams Custom, 370, TTi single 82mm Turbo, 10 psi, 3000ft, 3700lbs, 9/15/07
Ryan
Ryan
#105
WOW! Looks like I have my work cut out for me. I will get to this next week. I just got back from a 2 week trip in Europe and have some things to take care of.
Thanks for the posts and I will add them as soon as possible.
#107
Since the title in the first post states:
"If your pig flies, list it here. Rules are as follows. Min Race Weight is 3500lbs and LSX or LTX powered. No other rules. One list for NA and one for PA."
Please add me to the list.
N20Dave, 10.15 @ 133.92 (1.49), 1995 Z28, G-force 5speed, 4.30, 396ci LT1, SR, SB2.2 heads, 400', 3780, 11/22/07
Thank you.
Thank you.
#108
Thank you.
Thank you.
#109
12.49 @107.25 (1.76) 06' TrailBlazer SS, 4L70E A4, Vig 3400, LS2, 364 ci, 224/230 comp cam, stock heads, +1300 DA, 4750 lbs., 10/2007
should have a faster tiime posted by this time tomorrow.
#112
I did some research and it seams you need 23* heads to be considerred an LTX even if they are modified SBC heads (according to the LTX shootout rules). BUT I am strongly considerring splitting the lists. I want to keep true to the sight being LS1tech and all and make one list just for LSXs and another for anything under the sun. How does that sound? I know I can't please everyone.
It doesn't say it's not an LTX motor if the 23* angle is not retained. It adds a weight penalty but still recognizes it as LTX.
I am registered and racing in outlaw in the LTX event so does that make it o.k.????
What makes it an LTX is the block and the reverse cooling system which is the limiting factor for everyone running an LTX type motor. It doesn't matter what heads you have or how big your turbo is, the factory block only takes so much.
I get cranked up about this because it took so much extra work to keep this thing an LTx based motor. I guess I'd like it to be recognized. I do give you credit for taking the time to start this list in the first place and would still be happy if it were split.
Thanks.
#120
